Rv - Nissan Titan Forum
2016 Titan General Forum General discussion forum for the new 2016 Nissan Titan.
User Tag List
post #1 of 34 (permalink) Old 03-26-2019, 12:57 PM Thread Starter
htoal's Avatar
Quoted: 19 Post(s)
iTrader Score: 0 reviews
Rv
So my wife and I are about 95% sure we will be purchasing an RV soon but before we do I'm reaching out for a little help on situations. The RV we are looking at is a 21 ft pull behind. The hitch weight is 427 lbs and the total weight of the trailer is 5295 lbs. Is there a need is getting a weight distribution hitch? This will be my first camper I pull, so I'm pretty new with towing. Any help or any other insight would be appreciated.
htoal is offline
Advertisement
post #2 of 34 (permalink) Old 03-26-2019, 01:05 PM
DeadRiver's Avatar
Quoted: 1424 Post(s)
iTrader Score: 4 reviews
Send a message via AIM to DeadRiver
Re: Rv
The first rule of towing is never believe the sales sheet specs. How certain are you of those numbers?
You'll also want to know what the fully laden weight is with fluids, gear, groceries, etc.
Given the size and weight it doesn't seem like you'll need a WD set up though. Do you have a brake controller already installed?
2004 Sedona Titan LE CC 4wd
75,000 mi. 1/22/14
86.000 mi. 8/20/15
96,000 mi. 12/02/16
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
MVP Titans
Co-founder and President
Link to MVP Titans Facebook Page
I should stop having my suit dry cleaned, it seems to kill people.
I'm not worried, I have a Titan with 4wd and a pair of balls.
You can lead a moron to knowledge but you cannot make him think.
I should probably buy more bullets.
The darkest hour is before the dawn.
The Urinator™
DeadRiver is offline
post #3 of 34 (permalink) Old 03-26-2019, 01:21 PM Thread Starter
htoal's Avatar
Quoted: 19 Post(s)
Re: Rv
I do have a brake controller already installed..... GVWR is 6695.... again I'm going on what the spec sheet says.
htoal is offline
post #4 of 34 (permalink) Old 03-26-2019, 01:46 PM
4mula1fan's Avatar
Quoted: 1747 Post(s)
Garage
iTrader Score: 3 reviews
Re: Rv
I would use one for sure. It equals out the load for handling, and reduces sway. Both critical in towing.
It USED to look like this...
Pow ... ... ... ... ... ... ... ... ... ... ... ... ... .. .. .. . . Ding!
TrainingWheelsWhore™
ChumToeWhore™
08 Pro4X with peeling clear coat. Looks terrible!!
Wife's ride '12 Maxima S Limited Edition
2013 Coachmen Catalina 252RLS Santara Series
Click here for mods
My Pics
So long, Walrus (Wally). Forum legend. Friend.
4mula1fan is offline
The Following User Says Thank You to 4mula1fan For This Useful Post:
Rob J (03-26-2019)
post #5 of 34 (permalink) Old 03-26-2019, 01:48 PM
Rob J's Avatar
Quoted: 70 Post(s)
Garage
Re: Rv
100% true.
Definitely get yourself a WD.
Rob J is online now
post #6 of 34 (permalink) Old 03-26-2019, 03:20 PM
HRTKD's Avatar
Quoted: 1119 Post(s)
Garage
iTrader Score: 2 reviews
Re: Rv
It's almost never wrong to use a WDH, mainly because most of them come with sway control built in. If you never encounter wind or other vehicles passing you then a WDH is probably optional. Using a WDH usually results in a much more comfortable towing experience.
Some Titans are a little light on how much trailer they can handle. It mostly comes down to if you have the tow package and the lower rear end axle ratio (3.36 vs 2.95 - 3.36 is better for towing). Look at the sticker on the driver's door frame. It will tell you the cargo capacity of the truck. As I recall, mine was somewhere around 1300 lbs, maybe less. This is as much weight as your truck is rated to carry. The tongue weight of the trailer is deducted from this amount. That leaves you a few hundred pounds for other cargo (people, luggage, etc).
The max tongue capacity of my Titan was 940 lbs as I recall. The owner's manual had a nice set of tables that let you know exactly what yours capacities are by matching your truck's features to those listed in the table.
«Granite '07 LE Crew Cab, 4x4, Big Tow, Off-Road» <-- Sold 07/2017
«ClearBra, Leer 100XQ, MM SI9500 Winch, Custom b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms, Hellwig rear sway bar»
2015 Nissan Leaf
2017 Ford F-350 CCLB 6.7L Lariat - The Towing Beast
Jim aka Bionic Whore™, Tutu Whore™
HRTKD is offline
The Following User Says Thank You to HRTKD For This Useful Post:
reddirtross (03-26-2019)
post #7 of 34 (permalink) Old 03-26-2019, 04:25 PM
Mach1tosh's Avatar
Quoted: 30 Post(s)
Re: Rv
Your setup is pretty much the same as mine. I use a WD hitch and Timbren spring assist as the rear leafs tend to be pretty soft on the Titan.
Since last towing season I have added Bilstien 5100 shocks to the rear as well so I'll be looking at the setup on the WD soon.
The WD makes it much easier to get the truck level as opposed to nose high while towing which affect steering feel and gets you a lot of high beam flashing while driving after dark.
You really can't go wrong for the investment as it can be moved from trailer to trailer and pays off in more relaxed towing.
Mach1tosh is offline
post #8 of 34 (permalink) Old 03-26-2019, 04:39 PM
Clint's Avatar
Quoted: 267 Post(s)
Re: Rv
That’s a bit of weight for only 21 feet of trailer, which one is it?
Clint
1991 Mazda Miata Limited Edition
2012 Dodge Challenger SRT8 Yellow Jacket
2014 Nissan Sentra SR
2016 Jeep Wrangler Freedom Edition
2018 Nissan Titan SV Crew Cab 4X4
2018 Nissan Rogue SV AWD
Clint is online now
post #9 of 34 (permalink) Old 03-26-2019, 10:35 PM
Mach1tosh's Avatar
Quoted: 30 Post(s)
Re: Rv
'04 Jayco Jayflight 21FB, 4060 lbs. dry, 5800 GVWR. Not a "light" one, full steel frame and sturdy.
We like it for the 2 of us, queen bed in the front and I've added a few enhancements to the storage to allow for easier packing. Pulls easy with the Titan.
https://www.jayco.com/tools/archive/2004-jay-flight-tt/
post #10 of 34 (permalink) Old 03-27-2019, 06:21 AM Thread Starter
htoal's Avatar
Quoted: 19 Post(s)
Re: Rv
Thanks for all the insight.... We live in south Texas so it's rarely extremely windy. The trailer we are sold on is a Grand Design Imagine series. Here is the link for it.
https://www.granddesignrv.com/showro...orplans/2150rb
htoal is offline
post #11 of 34 (permalink) Old 03-27-2019, 06:26 AM
HRTKD's Avatar
Garage
Re: Rv
GVWR is 6700 lbs. THAT is the weight you should be focused on. Still within the Titan's towing capacity even if you didn't have the tow package.
2015 Nissan Leaf
HRTKD is offline
post #12 of 34 (permalink) Old 03-27-2019, 07:54 AM
Clint's Avatar
Quoted: 267 Post(s)
Re: Rv
Very nice, if needed can you use it with the slide in? I’ve seen some you can’t walk through unless it’s open.
What’s the list price on that one?
Clint
Clint is online now
post #13 of 34 (permalink) Old 03-27-2019, 09:59 AM
Quoted: 15 Post(s)
Re: Rv
I would say absolutely on the WDH.
There are lots of fancy options out there, but with a smaller lightweight trailer you don't necessarily have to go high end.
I tow a Jayco X19H (21' total length and around 5K lbs loaded). I have a simply Husky roundbar hitch with anti-sway. As simple as they get, and not overly expensive. You will certainly feel the difference in handling as the weight is returned to the front axle of the truck and you tow much more level. Note that you may need the longer drop shank than stock for the Titan/Jayco combo depending on the TT frame height. With a small trailer and taller truck it is worth knowing the hitch and coupler heights when ordering your WDH setup so you have the correct range of adjustment. Also, get a WDH with the correct bar weight range for your trailer; bigger is not better with a WDH, the bars should be matched properly to the actual load.
bankr63 is offline
The Following User Says Thank You to bankr63 For This Useful Post:
htoal (03-27-2019)
post #14 of 34 (permalink) Old 03-27-2019, 01:41 PM Thread Starter
htoal's Avatar
Quoted: 19 Post(s)
Re: Rv
Clint
You can use it with the slide in.... That was one of our main selling points with this model. List price was 37k but I've been playing 3 dealerships and have got them down to 22k drive out. My job is a contract negotiator so I'm a sales mans worst enemy.... Same with my titan. Just trying to work out the towing aspect of it now.
htoal is offline
post #15 of 34 (permalink) Old 03-27-2019, 02:18 PM
Clint's Avatar
Quoted: 267 Post(s)
Re: Rv
What a great price, I’d buy one. Good luck.
Clint
Clint is online now
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Linear Mode Linear Mode
small RV to tow: recommendations or web-sites? pluckyew Titan Towing & Hauling 6 09-01-2006 02:22 PM
Le Rv Mirror Display bktitan Titan General Discussion 2 12-20-2004 08:03 PM
Nissan Titan on RV TODAY show NDJollyMon Titan General Discussion 1 08-21-2004 01:30 PM
First trip towing RV with the Titan karlconnell Titan General Discussion 8 03-19-2004 05:33 AM
used RV market and information on the net? pluckyew Titan General Discussion 0 02-24-2004 01:23 PM
You may post new threads
You may post replies
