in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Menu
Log in
Register
Home
Forums
1st Generation Nissan Titan Forum (2004-2015)
Electrical & Wiring
Follow Forum
Create Post
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
Go to page
Go
62
Next
1 of 62
Go to page
Go
Sticky
Frequently asked fuse locations.
baseballfanz
Jan 25, 2013
41
285K
12 d ago
by
nectromatheny
G
Break lights stuck on, stop lamp circuit code
Gear413
Dec 12, 2019
17 h ago
by
AxeMan2012pro4x
D
rear window motor(s) failing
drgrcr
1 mo ago
2K
2 d ago
by
drgrcr
J
Ecu relay help
Jbnowa
4 mo ago
3
2K
3 d ago
by
ajef7885
Loss of power with lights on.......
kyle1_1
Oct 9, 2018
7
2K
5 d ago
by
ayman_elhacha
Radio issue
BarisB
5 d ago
0
304
5 d ago
by
BarisB
Starter Troubles - Sometimes It Does Nothing, Then Eventually Cranks Right Up ???
shinerecording
9 mo ago
7K
13 d ago
by
Warhammer
2012 Service Manual Missing HAC (Heater and Air Conditioning Control) section
Loopy74
14 d ago
1
612
13 d ago
by
dubyam
S
Oil pressure light, temp light, oil pressure gauge to 0 randomly
Sprucemoose
Nov 14, 2015
8
7K
17 d ago
by
busemans
2007 Titan won't start: Immobilizer or Fuel Pump?
Wingfeather
22 d ago
5
1K
18 d ago
by
seymore4
What a difference (new LED back up lights)
2020Pro4X
Nov 21, 2020
17
3K
22 d ago
by
busemans
The dreaded shift lock/ no brake light issue!!!
Mayesmf
23 d ago
1K
23 d ago
by
Mayesmf
J
truck turns over but wont fire.
jer760
Dec 5, 2012
13
9K
28 d ago
by
DasGoat
J
05 Ignition -Intermittant No CRANK. It's the Ignition SWITCH! And an EASY way to check the starter.
Jim Padget
Mar 2, 2021
4
6K
1 mo ago
by
Jim Padget
ECM FROM 07 no longer made none available any where!
Nitrolico
1 mo ago
1
2K
1 mo ago
by
busemans
2012 Pro4X no interior outlets "Hot" while car is off
Kuma Style
7 mo ago
5
3K
1 mo ago
by
AxeMan2012pro4x
2004 Nissan Titan Security is on all the time
joshuataylor686
2 mo ago
9
2K
1 mo ago
by
seymore4
Instrument gauges not working - possible ground or fuse problem
Kick It Out Titan
10 mo ago
1
2K
2 mo ago
by
LSURulz35
2017 AC long cycling times
cramgnarts
2 mo ago
1
2K
2 mo ago
by
busemans
Power Door Locks
kmr481
Nov 27, 2011
10
5K
2 mo ago
by
Scamper
C
(2010)Relays and Anti-theft preventing truck to start
colin.murphy81
Sep 15, 2018
1
5K
2 mo ago
by
AShelby
N
2005 TITAN ECM GROUND WIRE COLOR
Nick20910033
Aug 6, 2021
3
3K
2 mo ago
by
chipgotay
No crank, no diagnostic communication, no fuel, please help
Bmagnum
2 mo ago
4
2K
2 mo ago
by
dubyam
Helping my ignition
Khawktitan05
2 mo ago
2K
2 mo ago
by
seymore4
What holds the 4wd switch in place?
Bigcountry78
2 mo ago
7
3K
2 mo ago
by
Bigcountry78
T
U1000 & c1130
titan556
Jul 4, 2017
4K
2 mo ago
by
Gilmar
B
IPDM & ECU blown?
BJS02SS
2 mo ago
3
2K
2 mo ago
by
feraille
i have a 2008 titan with a locked up vvt engine. i bought a 2005 non-vvt engine. will it work?
jonathonleighcrary
2 mo ago
7
2K
2 mo ago
by
busemans
A
Adding fog lights
Andrew181
Sep 27, 2011
14
11K
3 mo ago
by
John the man
S
Wiring Aftermarket Parking Sensors
SXT80
3 mo ago
0
2K
3 mo ago
by
SXT80
Elecrtical Issues!
mackservices
3 mo ago
3K
3 mo ago
by
dubyam
C
No rear running lights, need some help
cicerocf
4 mo ago
15
3K
3 mo ago
by
apetro02
A/C Will Not Turn On - Possible Bad BCM
Loopy74
3 mo ago
0
2K
3 mo ago
by
Loopy74
W
How to mount UHF antenna
WildApe
3 mo ago
2K
3 mo ago
by
busemans
K
06 Nissan Titan fuse keeps blowing
Kbo2016
Mar 22, 2021
6
3K
3 mo ago
by
busemans
R
Backup sensor (sonar) issues / questions
rbahr
3 mo ago
0
2K
3 mo ago
by
rbahr
1
Go to page
Go
62
Next
1 of 62
Go to page
Go
Join the discussion
Continue with Facebook
Continue with Google
or
sign up with email
Electrical & Wiring
Forum for discussion of all your Electrical & Wiring troubles and needs. Sponsored by Optima Batteries.
Show more
13K
posts
5.6M
views
Join Community
Grow Your Business
Forum Staff
View All
RobKar
Carbeaux
37L1
Top Contributors this Month
View All
busemans
Mayesmf
SeanDavy
Join now to ask and comment!
or
sign up with email
Home
Forums
