Camber too high after Icon 3" lift - Nissan Titan Forum
Engine and Technical Discussion Discussions of the Nissan Titan Cummins Engine and Powertrain
User Tag List
post #1 of 4 (permalink) Old 06-17-2019, 11:02 AM Thread Starter
Quoted: 19 Post(s)
iTrader Score: 0 reviews
Anyone do a 3" lift and have too much positive camber? Icon kit, camber bolts adjusted all the way, and still getting 1.5 and 1.7 camber. Three alignment shops already. Is this visible camber to spec with these lifts? any thoughts on how to lower camber?
jshortsl is offline
Advertisement
post #2 of 4 (permalink) Old 06-18-2019, 09:02 AM
honda250xtitan's Avatar
Quoted: 127 Post(s)
Garage
iTrader Score: 9 reviews
Re: Camber too high after Icon 3" lift
with a lift you don't necessarily want to go with OEM specs (especially since its an A arm setup). Call ICON and see what they recommend you get aligned to. Then find a good shop to do it, not Firestone, Dealership, etc.
2017 F250 6.7: Icon, Baja Designs, Nitto, Retrofit Headlights
Gone2011 White CC Pro4x
All the things Build Thread: https://www.titantalk.com/forums/tit...ld-thread.html
DIRT KING FABRICATION, FOX, TOYO, FUEL, PRG, GIBSON, BORA, AIRAID
Now stock AF
Traded In: 06 KingCab 4x4
Don't be a dummy, use this before asking https://www.titantalk.com/forums/search.php
honda250xtitan is offline
post #3 of 4 (permalink) Old 06-18-2019, 01:55 PM
Titanrunner04's Avatar
Quoted: 52 Post(s)
Garage
You may have to get a new upper arm that is adjustable like Dirtking. It will allow you to pull the upper arm without binding on the coil bucket because of its tubular design. Or if the Icons are adjustable which I think they are lower it a little which will bring the camber more negative at ride height. If you are all the way up on the suspension cycle meaning almost fully drooped out it will be tough to get rid of the positive camber.
Jason
Titanrunner04 is offline
The Following User Says Thank You to Titanrunner04 For This Useful Post:
honda250xtitan (06-18-2019)
post #4 of 4 (permalink) Old 06-18-2019, 02:47 PM
Quoted: 127 Post(s)
Garage
this is true. not to mention ride quality will be better
Now stock AF
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Linear Mode Linear Mode
Be an ICON!!! Get ICON Vehicle Dynamics Coilovers Mike @ TAP Titan Parts & Accessories 22 09-19-2013 03:30 PM
Be an ICON!!! Get ICON Vehicle Dynamics Coilovers Mike @ TAP Titan Performance Modifications 6 12-24-2012 07:55 AM
Too Fast! Too Fast! Too Fast! Quartz Off-Topic Discussion 13 11-02-2011 04:23 PM
Fixing camber without camber bolts??????? HELP damerowalex Titan Wheels, Tires & Brakes 10 08-25-2009 08:28 PM
too fast too furious too stupid troutking Off-Topic Discussion 27 05-31-2006 07:57 PM
You may post new threads
You may post replies
