2005 Titan cracked exhaust header, passenger side - Nissan Titan Forum
New Member Introductions Are you new to TitianTalk.com forum? Post up and introduction to yourself , and meet new members in this section.
User Tag List
post #1 of 10 (permalink) Old 07-11-2019, 07:03 PM Thread Starter
Quoted: 1 Post(s)
iTrader Score: 0 reviews
I love this truck, however the cracked exhaust header sound is annoying. The local dealer's price to replace with an OEM parts was quoted at $1,450 including labor.
Any helpful suggestions would be appreciated.
Thank you in advance - John
JMeyer is offline
Advertisement
post #2 of 10 (permalink) Old 07-11-2019, 10:45 PM
Quoted: 8 Post(s)
Re: 2005 Titan cracked exhaust header, passenger side
At close to 200k I couldn't justify tube headers and retuning the motor so I replaced mine with aftermarket and they didn't last hardly a year. These didn't just crack, they had pieces falling out. And on the drivers side an entire weld circling the pipe separated from the main manifold pipe completely. Luckily I kept the originals which just had one stress crack each, and welded them up myself and put them back on TODAY as a mater of fact. It is a huge pain of a job to do yourself. You'll need every extension, wobble, u-joint and curse word you have -and a torch to heat the nuts red or they'll never break loose so plan on replacing those header nuts and the header gaskets of course . Also you'll need to block the drivetrain up and remove both motor mounts, the passenger side is a bear and it had to come apart even. The Dip Stick tube has to come out and even it put up a fight. Make sure and blow out any debris where it goes into the block then soak with WD then pull straight out, it's an o-ring seal that just pushes in and out, but it doesn't seem to want to turn loose easily at first. Don't waste your time on aftermarket replacements, just weld 'em up and put them back on. GOOD LUCK.
Jim Padget is offline
post #3 of 10 (permalink) Old 07-12-2019, 06:23 AM
seymore4's Avatar
Quoted: 49 Post(s)
iTrader Score: 215 reviews
OEM parts WILL CRACK AGAIN. Welding the cracks as well WILL FAIL AGAIN. You don't want to have to do this job twice.
If you plan on keeping the truck check out our permanent fix. www.cajunbpipes.com
Uprev Guru for Cajun B pipes
www.cajunbpipes.com
seymore4 is offline
The Following User Says Thank You to seymore4 For This Useful Post:
vector6 (07-12-2019)
post #4 of 10 (permalink) Old 07-12-2019, 08:08 AM
54warrior's Avatar
Quoted: 31 Post(s)
iTrader Score: 2 reviews
yep, cajun b pipes is your best option.
Truck: 05 CC SE 4x4
Performance/Drivetrain: JBA CAtback w/ 2* Advance, PRG Driveshaft Spacer, PRG Street Traction Bars
Suspension: PC 6", SAW Coils, ProComp MX6 Adjustable Rear Shocks, Total Chaos Shackles, removed anti-sway bar
Wheels/Tires: Stock 6 Spoke Charcoal Wheels with Nitto Terra Grappler G2's-325/65R-18
Brakes: Stock w/ PRG Stainless Lines (Front)
Lighting: (3) Hella 500 Driving Lights
Misc: Husky Liners, Bug Shield, Tonneau, Bed Liner'ed Rockers, Home-MadeŠ Skid Plates, Vent Visors
54warrior is offline
The Following User Says Thank You to 54warrior For This Useful Post:
post #5 of 10 (permalink) Old 07-12-2019, 08:14 AM
vector6's Avatar
Quoted: 12 Post(s)
Hello John, and Welcome from Texas!
if you plan on keeping the truck, cajun Bpipe it.
Texas!
USN Vet Fly Navy!
vector6 is offline
post #6 of 10 (permalink) Old 07-12-2019, 09:18 PM
Quoted: 12 Post(s)
iTrader Score: 1 reviews
Welcome to Titan ownership. This is a common problem and replacing the exhaust manifold with stock will likely crack again. You need to talk with Jeff at Cajun B Pipes and Joe at Cajun Tuning before making any decisions. No regrets here.
https://www.cajunbpipes.com/
2007 Nissan Titan LE - Tow package - Blizzard White with painted Armada Air Dam - Truxedo Low Pro tonnau cover - Slotted Frozen Rotors with Hawk Performance LTS brake pads - Goodridge Stainless brake lines - Bilstein 5100 shocks with 1" lift setting - JBA stainless headers and Cajun Hi Flow Catted B pipes Jet Hot ceramic coated in Titanium - Cajun cat back exhaust with JBA 40-30220 muffler - Vibrant Ultra Quiet resonator - Blastin' Bobs 4" stainless double wall resonated tip - Axle vent mod
MuskieHunter is offline
post #7 of 10 (permalink) Old 07-12-2019, 10:24 PM
Quoted: 4 Post(s)
Call cajun and be done. Only solution.
MiloM is offline
The Following User Says Thank You to MiloM For This Useful Post:
JMeyer (07-13-2019)
post #8 of 10 (permalink) Old 07-13-2019, 06:48 AM Thread Starter
Quoted: 1 Post(s)
Great information. Thank you Jim!
JMeyer is offline
post #9 of 10 (permalink) Old 07-13-2019, 08:59 AM
TA CC TX's Avatar
Quoted: 2 Post(s)
Garage
iTrader Score: 5 reviews
Ok , Two things do you want to keep the truck for a long while and are you able to do the job yourself. if you are paying a shop you sure don't want the aftermarket cheapo's. If you think you would be wasting money on after market headers / catalytic converters and you bought the eastern or magnaflow one piece cats/manifolds you would be right. if you installed all that and then welded your old cats back up and installed them after the failed pacesetter,eastern, magnaflow that sounds like more wasted time to me. Now with all due respect I am sure Jim's newly installed manifolds with the patch welds will crack again soon.But of course the best of luck on that. I did mine in 2012 and no problems since.I did it in stages started with B-pipes ,then did upRev then put the headers on.More affordable that way and you can see the difference with each step. https://www.titantalk.com/forums/tit...-2004-4x4.html https://www.titantalk.com/forums/tit...t-freedom.html
[04 CC BT OFFROAD / UpRev tuned by RB /Jim Wolf Tech s7/s2 Cams/ Doug ThorlyLT Headers/ Cajun Hi flow catted B-Pipes/ Cajun Y pipe/ 16" Borla XR-1 / Vibrant UQ reso/ 07+ Manifold / Airaid MXP CAI / Long Tru-Cool Transmission Cooler / 170* Thermostat / Tb coolant By-pass / trans radiator By-Pass / CFS Radiator / MetalWorx Street Traction Bars / Hellwigg traction springs / 2014 3.36 Diff /Custom Ram Air / Suncoast Functional Ram Air Hood /Active Tuning Grounding Kit / Wolo Powerhouse Air Horn!
TA CC TX is offline
post #10 of 10 (permalink) Old 07-14-2019, 07:24 AM
seymore4's Avatar
Quoted: 49 Post(s)
Dorman as well. We've got calls from guys who had them fail in less than 6 months. They say they warranty the part, but the LABOR to uninstall/ reinstall the new one is on you. Just not worth it
www.cajunbpipes.com
seymore4 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Linear Mode Linear Mode
Cracked Exhaust Header? Justintoxicated Titan Problems & Dealer Service 27 12-22-2014 02:07 AM
Cracked exhaust need header advice HGaither Titan Performance Modifications 35 12-12-2014 04:01 AM
1 side header 1 side stock manifold Easy88 Titan Engine, Transmission & Drivetrain 25 11-23-2013 01:05 PM
OBX Passenger side LT header install fit issue 200KTitan Titan Performance Modifications 116 11-28-2011 02:57 PM
2005 OEM Grey Step Bar(Passenger Side) manyowa Titan Parts & Accessories 0 11-15-2007 06:33 PM
You may post new threads
You may post replies
