Login / Join
What's New
Forum Listing
Showcase
Gallery
Advanced Search
FAQ
Dark Mode
Menu
Log in
Register
Home
Forums
Nissan Titan Tech Talk
Titan Engine, Transmission & Drivetrain
Follow Forum
Start Discussion
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show only:
Loading…
1
Go to page
Go
296
Next
1 of 296
Go to page
Go
Last
Sticky
Rear axle seals leaks. Please report.
H
Herbpov
Aug 11, 2006
39
40
41
819
231K
8 days ago
by
titan14
Sticky
Transmission drain and fill???
R
razoo125
May 20, 2010
4
5
6
118
133K
4 months ago
by
matt20
Sticky
How to replace the starter Nissan Titan
RobKar
Feb 17, 2013
3
4
5
90
155K
9 months ago
by
turtlesharkshooter
Sticky
My experience DIY-ing the front differential in a Titan.
ten~39
Feb 9, 2010
4
67
82K
10 months ago
by
LightShow
Sticky
4x4 on dry pavement,Not!
T
tillery444
Sep 12, 2006
3
4
5
99
60K
Nov 14, 2018
by
rackoflam11
Sticky
Thinking about a TruTrac install---What all do I need?
jetchaser
Sep 18, 2010
5
6
7
132
77K
Apr 29, 2018
by
05T1TAN
Sticky
Dana's Response about failures
Shane06fl
Oct 18, 2007
6
7
8
159
86K
Dec 6, 2017
by
Doneuald
Sticky
08+ Titans do NOT have 35 spline axles!!!!
josh19k
Jan 27, 2012
14
15
16
303
93K
May 18, 2017
by
mxm64
Sticky
Diff and Gear Swap Info
CL 8 2WD
May 25, 2010
19
51K
Mar 13, 2017
by
irikumi
Sticky
How to change drive belt
F
Fieldworks
Sep 27, 2008
64K
May 7, 2015
by
CalcityRenegade
Shifter cable connection at the Column problem!
Black Knightmare
Sep 6, 2013
53
59K
1 day ago
by
Burris
2004 NissanTitan 4wd will not disengage.
S
ssand746
8 days ago
6
198
2 days ago
by
sp3ce
Trans feels sluggish
R
Redleg68
5 days ago
1
137
5 days ago
by
matt20
2017 not backing up
Richierich11
5 days ago
5 days ago
by
wanderMT
IPDM For 2004 Titan? Wich Model?
B
BigZ
Jan 18, 2013
14
7K
7 days ago
by
Idkd323
The never ending smoke issue
K
Keyman
7 days ago
9
226
7 days ago
by
teecro
Need new O2 Sensors
Dook-E
Jan 1, 2015
9
1K
8 days ago
by
smschulz
Trans problems
Carshop24
11 days ago
4
195
11 days ago
by
Carshop24
07 Titan wont start in the cold
strat468
Nov 13, 2014
18
5K
11 days ago
by
DoubleAR
Replacing rear axle shafts
MikeNokes
12 days ago
0
268
12 days ago
by
MikeNokes
won't shift from park
D
devilmole
Nov 28, 2011
20K
14 days ago
by
Fastone2007
2012 SV - loud grinding noise in the front end
2012.SV.owner
2 months ago
3
331
15 days ago
by
DoubleAR
Vibration that I can't find
R
ronwaynetilley
15 days ago
1
158
15 days ago
by
DoubleAR
Transmission won't shift out of high gear
T
tmull35
Mar 12, 2011
10
9K
15 days ago
by
LSURulz35
07 titan oil
Cobra2216
21 days ago
14
494
15 days ago
by
Jim Padget
Front Wheel Bearings (Hub Assembly)...How to Diag?
M
Mark_H
3 months ago
15 days ago
by
2012.SV.owner
Acceleration problem!
A
AdventureT85
Apr 12, 2015
10K
18 days ago
by
Steven6676
W T F is going on
Kitan
23 days ago
3
404
21 days ago
by
Kitan
Fuel pressure test port???
mrcarnage2
22 days ago
0
130
22 days ago
by
mrcarnage2
adding factory cruise control
B
boost_junkie21
Feb 8, 2008
8K
24 days ago
by
Uniquabest
1
Go to page
Go
296
Next
1 of 296
Go to page
Go
Last
Join the discussion
Continue with Facebook
Continue with Google
or
sign up with email
Technical discussion about the engine, transmission, and drivetrain.
59K
posts
17.9M
views
Join Community
Forum Staff
View All
Carbeaux
Arachnid
RobKar
Top Contributors this Month
View All
4mula1fan
Cobra2216
sp3ce
Join now to ask and comment!
or
sign up with email
Home
Forums
