Strange things happening in trans - Nissan Titan Forum
User Tag List
post #1 of 24 (permalink) Old 05-23-2019, 03:43 AM Thread Starter
midnightmadman's Avatar
Quoted: 7 Post(s)
iTrader Score: -1 reviews
My transmission temperature keeps getting very hot while driving in overdrive up mild inclines but everything seems perfect and it shifts fine the only other issue I noticed is when I put it in park and put it back in to drive it does not want to engage it will rev up sometimes it will catch and grab and lunge forward but if I put it down it to second or first it usually will engage much easier. If I stop at a light and it stays in gear everything operates as normal. It’s onlt if I put it into park and then try to move again. The indicator on the dash is reading its in the correct gears.
midnightmadman is offline
Advertisement
post #2 of 24 (permalink) Old 05-23-2019, 03:45 PM
honda250xtitan's Avatar
Quoted: 126 Post(s)
Garage
iTrader Score: 9 reviews
Re: Strange things happening in trans
oh boy good luck with the tranny overheating issue. I had similar problems. but much worse....sitting at lights it'd overheat. added an auxiliary transmission cooler and it masked the overall issue. sold it before i found out what was wrong.
2017 F250 6.7: Icon, Baja Designs, Nitto, Retrofit Headlights
Gone2011 White CC Pro4x
All the things Build Thread: https://www.titantalk.com/forums/tit...ld-thread.html
DIRT KING FABRICATION, FOX, TOYO, FUEL, PRG, GIBSON, BORA, AIRAID
Now stock AF
Traded In: 06 KingCab 4x4
Don't be a dummy, use this before asking https://www.titantalk.com/forums/search.php
honda250xtitan is offline
post #3 of 24 (permalink) Old 05-24-2019, 02:09 AM Thread Starter
Quoted: 7 Post(s)
Great
What’s a transmission cost for these trucks ? It’s a 2008
The overheating thing isn’t really the biggest issue I put some kind of conditioner in it and it hasn’t happened since.. it’s the not going into drive thing now. It will engage in 2-1 but not 3-4-D
post #4 of 24 (permalink) Old 05-24-2019, 04:39 AM
slyfur1's Avatar
Quoted: 420 Post(s)
iTrader Score: 0 reviews
Originally Posted by midnightmadman View Post
Great
Couple questions
What's the condition of your trans fluid?
How long have you owned it and how often you change trans fluid?
Original radiator?
What's the color of your radiator fluid in the radiator, don't check hot?
Sounds like either a torque converter going south or the internal trans cooler in your radiator failed and is leaking into your coolant system.
2018 KC Deep Blue Pearl, VK56VD, Pro4X, bought new, 13K mi
2006 KC Majestic Blue Frontier, Nismo 4x4, V-6 4.0, 6Spd, bought new, 147K mi "Sold"
I prefer not using remote start or drive-thrus, both hurt your MPG's a lot & you shouldn't let your vehicle idle more that a minute or so especially unattended.
Remember oil isn't a renewable energy source. One day it will all be gone?
Mods: OLM LED fog lights ALPHA HD (PHILIPS Z ES), Iron Cross Black Endeavour Running Boards, WeatherTech floor mats and window visors, AVS aeroskin bug defector, K&N PAIS PN 63-6019,
slyfur1 is offline
post #5 of 24 (permalink) Old 05-24-2019, 06:29 AM Thread Starter
Quoted: 7 Post(s)
Great
Couple questions
Original radiator?
The transmission sprung a leak last year while I was going up a hill
A line blew off and I had to turn around to coast back down the hill
They fixed the leak and refilled with the Nissan fluid
I checked the fluid the other day hot and it was good
Everything was fine forvthe last year
Before this issue I was getting a strange slipping thumping feeling but strangely it went away when this problem seemed to start
I also had a new radiator put in about 2 years ago but I didn’t think that would be part of the issue ? Maybe something went wrong with how it connects to cool the tranny? I haven’t check the radiator coolant in a while. I will tonight. What should I look for exactly?
Why would it go in gear in 2-1 from park but no other gear? Also why would it drive perfect and shift perfect if not put out of gear and back in (like at a stop light)
post #6 of 24 (permalink) Old 05-24-2019, 06:53 AM
dubyam's Avatar
Quoted: 184 Post(s)
Sounds like your fluid loss caused some damage to the valve body and it took a while to manifest. Mine did the same and took about 2mo to give up. Yours lasted a lot longer.
You might see if a local transmission shop can do a valve body swap or rebuild and get you back on the road. Likely cheaper than a rebuild of the trans.
dubyam is offline
post #7 of 24 (permalink) Old 05-24-2019, 08:06 AM
slyfur1's Avatar
Quoted: 420 Post(s)
I agree with dubyam, people don't tell you whole story until we dig in a bit.
slyfur1 is offline
post #8 of 24 (permalink) Old 05-24-2019, 04:18 PM Thread Starter
Quoted: 7 Post(s)
Thanks
So the value body controls the actuation into gear? It’s odd because once it gets into gear from first with with shift perfect and I can manually shift through each gear etc
Also the truck has 153,000 miles on it
post #9 of 24 (permalink) Old 05-25-2019, 11:13 PM
dubyam's Avatar
Quoted: 184 Post(s)
The valve body controls all the shifting and fluid routing for gearing and such.
dubyam is offline
post #10 of 24 (permalink) Old 05-26-2019, 04:14 AM Thread Starter
Quoted: 7 Post(s)
I took a look at the coolant and didn’t notice anything abnormal
post #11 of 24 (permalink) Old 05-31-2019, 03:46 AM Thread Starter
Quoted: 7 Post(s)
Is there a possibly I have two issues at the same time?
Someone was saying maybe it’s a linkage issue being that it only engages in 1st
It seems to still want to rev a bit before it feels like it “catches”
post #12 of 24 (permalink) Old 05-31-2019, 04:20 AM
slyfur1's Avatar
Quoted: 420 Post(s)
It all most likely stems from when the trans cooler hose busted, you transmission ran while low on fluid. Of course there could be 2 problems at the same time. I'm no transmission specialist, most of us aren't, take it to a transmission shop for T/Sing.
slyfur1 is offline
post #13 of 24 (permalink) Old 05-31-2019, 09:29 AM Thread Starter
Quoted: 7 Post(s)
It’s just odd because it shift flawlessly like it’s brand new once it’s in gear
post #14 of 24 (permalink) Old 06-01-2019, 04:18 AM
Dieselfuelonly's Avatar
Quoted: 3 Post(s)
I would suggest taking it to a transmission shop that is familiar with JATCO transmissions to be diagnosed.
One of many things that can be checked is the line pressure.
Hope this helps
2005 Titan
Long TruCool added w/ removal of radiator in the loop
Dieselfuelonly is offline
post #15 of 24 (permalink) Old 06-01-2019, 05:40 AM
Quoted: 1 Post(s)
Nissan Titan trannies are very finicky...
Without a HIGHLY refined fluid they will take a dump...
ANYTHING in that fluid i.e. the SLIGHTEST bit of coolant will wreak havoc on the internal clutches and send
bits of clutch material circulating throughout the valve body's tiny orifices moving about through one to the next
creating a myriad of strange intermittent issues...
As time goes by and more and more miles are driven the issues get more "dramatic."
Nissan engineers saw fit to circulate tranny fluid through the "Danger Zone"...
Although it makes engineering "sense" it fails miserably in "real life" use...
Experience with this issue too and have done a ton of research on it...
Mine tranny took a dump...
Wholesale cost on a new OEM valve body was $875.00...
Cost to rebuild the tranny was $1500.00...
Towing cost to the stealership for programming was $45.00...
Cost of programming was $115.00
2 1/2 weeks down to 1 vehicle with Wifey Pooh b*tch*n...
You do the math...
And I got by cheap !!!
2 pluses...
The "most current" tranny programming and
A 4 degree aka 2 degree timing advance...
Woo Hoo !!!
Rear tires will undoubtedly be next...
Luckymann77
'08 Titan LE Crew Cab LLLOOONNNGGG bed !!!
Timberline Green (AKA Black) with Almond interior
2" lift
Factory Rhino liner
Utilitrack
20" wheels
Aftermarket head lights and tail lights
Big A$$ Truck !!!
Luckymann77 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Just installed stereo...Weird things happening UofMMalibu21 Titan Visual & Audio Discussion 6 11-15-2013 10:59 AM
matic j fluid replaced by matic s drove 12,000 miles trans codes 1757 & 1759 strange? ab.titan Titan General Discussion 4 09-27-2011 11:56 AM
Weird things happening after Bullydog GT install… 97lowazznissan Titan Problems & Dealer Service 0 09-09-2011 07:16 AM
You may post new threads
You may post replies
