2004 Titan - Nissan Titan Forum
User Tag List
post #1 of 3 (permalink) Old 07-12-2019, 12:03 PM Thread Starter
Quoted: 0 Post(s)
iTrader Score: 0 reviews
2004 Titan
Well check engine light has been on for a while. Haven't driven since. Drove to AutoZone and almost didn't make it. Truck was fighting me the whole way. So they pulled the below codes. The sucker is either stopped up(Cats) or Af sensor. I bought the Bocsh Oxy precat Sensor and it didn't work. YThe truck is still shaking really bad.The CEL keeps coming on and truck is choking out, I don't know what else to do. How do you know for sure if a cat is stopped up? Any suggestions guys? Is m in the Ooltewah,TN area.
Codes thrown
P302
P1279
eembry is offline
Advertisement
post #2 of 3 (permalink) Old 07-12-2019, 09:14 PM
Quoted: 12 Post(s)
iTrader Score: 1 reviews
Re: 2004 Titan
P302
https://www.fixdapp.com/blog/p0302
P1279
https://www.engine-codes.com/p1279_nissan.html
https://www.titantalk.com/forums/tit...ctor-code.html
2007 Nissan Titan LE - Tow package - Blizzard White with painted Armada Air Dam - Truxedo Low Pro tonnau cover - Slotted Frozen Rotors with Hawk Performance LTS brake pads - Goodridge Stainless brake lines - Bilstein 5100 shocks with 1" lift setting - JBA stainless headers and Cajun Hi Flow Catted B pipes Jet Hot ceramic coated in Titanium - Cajun cat back exhaust with JBA 40-30220 muffler - Vibrant Ultra Quiet resonator - Blastin' Bobs 4" stainless double wall resonated tip - Axle vent mod
MuskieHunter is offline
post #3 of 3 (permalink) Old 07-13-2019, 07:09 AM
PanAm Ken's Avatar
Quoted: 17 Post(s)
Re: 2004 Titan
Welcome to the forum bro, I also have an 04. For your P302 code I would start by removing and inspecting the coil packs and spark plugs one at a time. 10mm bolt secures the coil pack. Remove it and take it to the bench along with the spark plug. Visual inspection of the plug will tell you to replace it or not. The coil pack you have to measure with a voltmeter the resistance across the terminals. If it is open, it is bad. The condition of the plugs will tell you how the previous owners maintained the truck. If you find a bad coil pack or 2 and don't have the $, I will send you some if you cover my shipping costs. I recently had a bad one and replaced all 8. I have 7 serviceable as removed coil packs available.
Your P1279 sounds like an exhaust leak to me.
Red Brawn LE
Senatobia, MS
TITAN's Build State
PanAm Ken is offline
The Following User Says Thank You to PanAm Ken For This Useful Post:
finallygotmeaTitan (07-15-2019)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Linear Mode Linear Mode
2004 armada 4x4 vs 2004 qx56 brudon82 Titan General Discussion 5 07-08-2011 11:03 PM
Raced a (2004-06) 1500 and (2004-2006) 2500 (diesel) Silverados chepdog War Stories 11 12-01-2008 01:47 PM
2004 cc Titan Vs 2004 Ford F350 Diesel w/chip x2thez Titan Engine, Transmission & Drivetrain 4 12-01-2006 09:17 AM
Traded 2004 Titan for 2006 Titan Red Brawn Titan General Discussion 20 10-09-2006 10:43 AM
You may post new threads
You may post replies
