2004 titan right rear axel seal leaking - Nissan Titan Forum
User Tag List
post #1 of 8 (permalink) Old 10-09-2018, 03:58 PM Thread Starter
Quoted: 1 Post(s)
iTrader Score: 0 reviews
I have a 2004 Titan, i found the right rear axel seal is leaking. local shop quoted me just over $500 to repair. they said need replace seal as well as what they called the toothed abs ring. does this price
seem right? i mean what would dealer charge?
alan d is offline
Advertisement
post #2 of 8 (permalink) Old 10-09-2018, 09:25 PM
Quoted: 65 Post(s)
iTrader Score: 1 reviews
Re: 2004 titan right rear axel seal leaking
I have had my "AXLE" seal quoted by independent shops and one dealer. Dealer was $785 each axle seal, independent shops were $500ish each axle seal. No one ever mentioned ABS ring to me. ABS ring isn't expensive or a big deal, you may want more quotes to be sure.
2007 Titan SE CC 4x4 BT
UpRev_Airaid MXP_JBA LT_Cajun B's_JBA CBE_Big Ol' Tip_Sylvania LED Bars_NHK G5R Projector Retrofit_Armada Brake Upgrade_Axle Vent Mod
TurboDA6 is offline
post #3 of 8 (permalink) Old 10-09-2018, 10:31 PM
Kitafur Fur's Avatar
Quoted: 10 Post(s)
Depends where you live. Here in the bay area I paid 1100+ to do both. After they were done it blew again within a week. After a horrible few thousand thrown into it I finally figured out what was blowing out my seals. Clogged axle vent. MAKE SURE YOU DO THE AXLE VENT MOD! Otherwise you'll keep throwing money away, I learned the hard way.
Kitafur Fur is offline
post #4 of 8 (permalink) Old 10-10-2018, 05:09 AM
54warrior's Avatar
Quoted: 26 Post(s)
iTrader Score: 2 reviews
AXLE VENT MOD IS A MUST! How many miles on that 04? Suprised it hasn't been an issue by now, this is very common thing. I believe most of the dealers are just replacing the bearing/seal/axle as an entire assembly because it is quicker and easier for them. You have to destroy the bearing to get the seal out anyway. I had 3 replaced on my 2005.
Again, DO THE AXLE VENT MOD soon after you get it fixed. More info here>>> https://www.titantalk.com/forums/tit...-solution.html
(sadly many of the pics are now gone from these old threads because of photobucket's new sharing policies)
Truck: 05 CC SE 4x4
Performance/Drivetrain: JBA CAtback w/ 2* Advance, PRG Driveshaft Spacer, PRG Street Traction Bars
Suspension: PC 6", SAW Coils, ProComp MX6 Adjustable Rear Shocks, Total Chaos Shackles, removed anti-sway bar
Wheels/Tires: Stock 6 Spoke Charcoal Wheels with Nitto Terra Grappler G2's-325/65R-18
Brakes: Stock w/ PRG Stainless Lines (Front)
Lighting: (3) Hella 500 Driving Lights
Misc: Husky Liners, Bug Shield, Tonneau, Bed Liner'ed Rockers, Home-MadeŠ Skid Plates, Vent Visors
54warrior is offline
The Following User Says Thank You to 54warrior For This Useful Post:
slyfur1 (10-10-2018)
post #5 of 8 (permalink) Old 10-10-2018, 03:09 PM Thread Starter
Quoted: 1 Post(s)
we have had the truck since new 139k miles on it now never had a seal leak till last week
alan d is offline
post #6 of 8 (permalink) Old 10-10-2018, 03:22 PM
slyfur1's Avatar
Quoted: 413 Post(s)
It's amazing how many people don't know about the rear axle vent issue. Then there's the OEM radiator trans cooler issue that they don't address until it's too late.
2018 KC Deep Blue Pearl, VK56VD, Pro4X, bought new, 12K mi
2006 KC Majestic Blue Frontier, Nismo 4x4, V-6 4.0, 6Spd, bought new, 147K mi "Sold"
I prefer not using remote start or drive-thrus, both hurt your MPG's a lot & you shouldn't let your vehicle idle more that a minute or so especially unattended.
Remember oil isn't a renewable energy source. One day it will all be gone?
Mods: OLM LED fog lights ALPHA HD (PHILIPS Z ES), Iron Cross Black Endeavour Running Boards, WeatherTech floor mats and window visors, AVS aeroskin bug defector, K&N PAIS PN 63-6019,
slyfur1 is offline
post #7 of 8 (permalink) Old 10-11-2018, 12:49 PM
Quoted: 10 Post(s)
@slyfur1 I've heard of this issue before. Do you care to elaborate or point me to some threads that explains this? I'm at 115k, no big issues other than the expensive issue of having to replace my whole rear end with an 07 because of leaky seals and my gears were loose and had a lot of metal shavings in diff oil. Wanted to flush transmission fluid but mechanic said he didnt sughest it because since I've waited thos long it could cause my transmission to prematurely slip. Just trying to do as much preventative measures now as possible.
post #8 of 8 (permalink) Old 10-11-2018, 01:15 PM
slyfur1's Avatar
Quoted: 413 Post(s)
I'm really surprised it's not a sticky it was on the ClubFrontier.org Forum for 2005-2010 Frontiers. Maybe it's not as big of a issue on Titans. But here's two threads I found doing a "SMOD" strawberry milkshake of death google search. Get a CSF radiator and be done with it.
https://www.titantalk.com/forums/tit...-radiator.html
https://www.titantalk.com/forums/tit...er-bypass.html
slyfur1 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Linear Mode Linear Mode
Right Rear seal leaking? mnb09 Titan General Discussion 3 09-26-2013 07:39 PM
Titan rear axel seals leaking quigley2003 Titan Problems & Dealer Service 4 06-26-2013 01:44 PM
Rear Axel Leaking jack Titan Problems & Dealer Service 14 09-09-2010 06:28 PM
Advice on rear axel seal leak ADK Stomp Titan Problems & Dealer Service 6 09-11-2009 01:23 PM
Rear axel seal went out again Molson Titan Engine, Transmission & Drivetrain 4 07-15-2009 08:34 PM
You may post new threads
You may post replies
