Fuse access - Nissan Titan Forum
User Tag List
post #1 of 5 (permalink) Old 05-12-2019, 03:28 PM Thread Starter
Quoted: 1 Post(s)
iTrader Score: 0 reviews
Fuse access
My trailer running lights are not working, I have brake and turn signals. I found were the F4 fuse is located under the hood, however the access is terrible in my 2012 Titan, I can’t squeeze anything down there to pull the fuse. Is there a way to easily mobilize that fuse panel or how have any of you found a way to get to it?
Jugghead is offline
Advertisement
post #2 of 5 (permalink) Old 05-15-2019, 09:51 PM Thread Starter
Quoted: 1 Post(s)
Re: Fuse access
Update for anyone wondering. I eventually found that the rear most fuse panel that is under the hood has tabs on each side near the top of the panel. When depressed this will allow the panel to slide up and out of place and provide access to the lower most fuses.
Jugghead is offline
The Following User Says Thank You to Jugghead For This Useful Post:
noel55 (05-16-2019)
post #3 of 5 (permalink) Old 05-16-2019, 05:17 AM
noel55's Avatar
Quoted: 98 Post(s)
Re: Fuse access
Yep you figured it out still a beyatch though
noel55 is offline
post #4 of 5 (permalink) Old 05-16-2019, 07:25 PM
Quoted: 8 Post(s)
Re: Fuse access
On the same subject, my F4 blows from time to time. (maybe once a year) Usually I'll pull my camper, with the 7-pin, and occasionally a light trailer with a 7 to 4 pin adapter. The little trailers seem to do it more often. Do any of you share my suspicion that 10 amps might be a little too small? I'm tempted to put a 15 amp in there. I've fully taken apart the 7-pin, there is nothing wrong there.
MartyG007 is offline
post #5 of 5 (permalink) Old 05-16-2019, 10:43 PM Thread Starter
Quoted: 1 Post(s)
Re: Fuse access
I haven’t had a problem until now, I was using a rented utility trailer with my 4 pin adapter. It blew the fuse 3 times and I just chalked it up to bad wiring on the trailer. I only tried the 10 amp though.
Jugghead is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Linear Mode Linear Mode
Can't access DRL T3 fuse on rear fuse panel - 2011 TitanZX Electronics 5 01-25-2017 05:16 AM
F/S 1/0 Fuse Holder (InLine Fuse) SD_Titan Buy/Sell 1 10-13-2010 11:18 AM
Oil filter access door ? Albert1234 Titan General Discussion 11 03-27-2004 07:12 PM
Access Cover availble April 5th... bvstone1 Titan Interior Discussion 2 03-22-2004 07:54 AM
You may post new threads
You may post replies
