Fluid leak - Nissan Titan Forum
User Tag List
post #1 of 5 (permalink) Old 05-13-2019, 09:35 AM Thread Starter
Quoted: 4 Post(s)
iTrader Score: 0 reviews
Fluid leak
For a few months now I've noticed a wet spot when I leave truck parked for a few days. I finally got under truck and pretty sure it's leaking from the hose or maybe through two bolts on pictures, it looks clean in pictures because I wiped it clean. It has a cable coming out going to rear, maybe emergency break? What is the hose attached to and if I remove the two bolts, will fluid come out? I tried back tracking the hose but didn't have enough time. 05 titan 4x4. Thanks for the help.
Gilv2071 is offline
Advertisement
post #2 of 5 (permalink) Old 05-13-2019, 10:47 AM
Titanrunner04's Avatar
Quoted: 48 Post(s)
Garage
Re: Fluid leak
That is just a Ebrake cable and mount. No fluid will come out when you remove the bolts. The Fluid looks like it coming from the transmission pinion seal for the drive shaft. When it spins it flings fluid all over the place.
Jason
Titanrunner04 is offline
The Following User Says Thank You to Titanrunner04 For This Useful Post:
slyfur1 (05-13-2019)
post #3 of 5 (permalink) Old 05-14-2019, 09:58 AM Thread Starter
Quoted: 4 Post(s)
Re: Fluid leak
Ok, I was thinking fluid was running down hose from someplace. Is this DIY job? Will it get worse if not fixed?
Thanks Titanrunner04
Gilv2071 is offline
post #4 of 5 (permalink) Old 05-14-2019, 10:56 AM
Quoted: 48 Post(s)
Garage
Re: Fluid leak
Its not a hard job at all. You have to remove the drive shaft and you will see the pinion seal where the drive shaft slides in. The seal is cheap and and easy to replace once the shaft is removed. While you have the shaft out inspect or take it to a drive line shop to have it looked also. Some shops will drill a tiny hole in the back of slip yoke to allow for drive shaft plunge, this will help the seal last longer also. I don't really know if there is any true value to this. Mainly just have them check the u-joints and carrier bearing if it is a crew cab. They should also balance it. You can also just look at it your self and make the judgement call, but if you have high miles the drive shaft will probably need what I described above.
Jason
post #5 of 5 (permalink) Old 05-14-2019, 11:56 AM Thread Starter
Quoted: 4 Post(s)
Re: Fluid leak
Ok, sound good and yes it's a crew and high miles. I'll tackle it as soon as I can.
Thanks again.
Gilv2071 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
"J" tranny fluid vs "S" tranny fluid??? dan200 Titan General Discussion 5 06-11-2011 07:45 AM
What tranny fluid is compatible with stock fluid? rynomx785 Titan Engine, Transmission & Drivetrain 2 05-11-2011 05:52 PM
Radiator Busted....Trans fluid in coolant and coolant in trans fluid boggs0214 Titan Performance Modifications 35 05-20-2009 04:14 PM
J Matic fluid now supercedes to S Matic fluid ten~39 Titan Engine, Transmission & Drivetrain 6 02-25-2009 07:35 PM
Diff Fluid....Which fluid do I use????!! BRACEYOSELF777 Titan General Discussion 7 01-25-2007 06:05 PM
You may post new threads
You may post replies
