Engine Runs Fine at Low RPM, Horrible at High - Nissan Titan Forum
User Tag List
post #1 of 9 (permalink) Old 07-12-2019, 07:16 PM Thread Starter
Quoted: 1 Post(s)
iTrader Score: 0 reviews
So I've been having some issues with my 04 Titan. Cruising along runs fine. Put in neutral, rev the crap out of it, runs fine. Driving along, or pulling away, & mash the gas, rpms go up & just starts cutting out, missing, running like crap. It'll get up to 6000ish rpm but it sucks getting there, & also doesn't shift till you get out of the throttle. & no codes being thrown as to misfire or anything like that. Had it at the Nissan dealership, they said it was coils/plugs. About choked when they told me 1600. But here's the thing, a month or so ago I already replaced the coils & plugs because of another missing issue which turned out to be an O2 sensor. Once that was fixed, truck ran great until the other day when this started up. Well since I said no to Nissan doing it & I still had the old plugs & coils, I started mixing around. Even bought brand new, actual replacement NGK plugs, still the same issue. Now I am thoroughly convinced these are not the issue. Anyone ever run across something like this? Nissan said fuel pressures looked good but I'm wondering if its an injector clogged or something like that that when the engine is under a load, something can't keep up. Please help! Right now, some of the things I've been chasing are starting to lead me to another fix...a trade in.
bencor21 is offline
Advertisement
post #2 of 9 (permalink) Old 07-12-2019, 08:56 PM
Quoted: 12 Post(s)
iTrader Score: 1 reviews
Re: Engine Runs Fine at Low RPM, Horrible at High
Considering the age of the truck and taking a simple approach to start, have you tried running a few tankfuls of gas with seafoam to clean things out? I would look at this as a fuel delivery issue first. Things could be gunked up. I have had luck keeping my truck running good (225000 miles) by never running ethanol blended fuel and running a can of seafoam about 3 times a year, especially when I am taking a longer trip. You might have something else going on, but a few tankfuls and about $15 for a couple cans of seafoam would be a good start.
2007 Nissan Titan LE - Tow package - Blizzard White with painted Armada Air Dam - Truxedo Low Pro tonnau cover - Slotted Frozen Rotors with Hawk Performance LTS brake pads - Goodridge Stainless brake lines - Bilstein 5100 shocks with 1" lift setting - JBA stainless headers and Cajun Hi Flow Catted B pipes Jet Hot ceramic coated in Titanium - Cajun cat back exhaust with JBA 40-30220 muffler - Vibrant Ultra Quiet resonator - Blastin' Bobs 4" stainless double wall resonated tip - Axle vent mod
MuskieHunter is offline
post #3 of 9 (permalink) Old 07-13-2019, 08:20 AM
seymore4's Avatar
Quoted: 49 Post(s)
iTrader Score: 215 reviews
My guess is fuel pump
Uprev Guru for Cajun B pipes
www.cajunbpipes.com
seymore4 is offline
The Following User Says Thank You to seymore4 For This Useful Post:
vector6 (07-14-2019)
post #4 of 9 (permalink) Old 07-14-2019, 01:44 PM Thread Starter
Quoted: 1 Post(s)
seymore4, fuel pump could be a possibility, but when Nissan had it, they said fuel pressures looked fine 48-51 psi.
MuskieHunter, so a little more info. After my O2 sensor was replaced, within a day I got the check engine light on again but this was for code P0420 (i think) for the catalytic converter not doing it's thing. Took it back to Nissan & they said, yeah it's near the threshold, drive it a bit & see if it goes away. If it doesn't you need a new cat. Their price of $1800 was laughable. So I dumped a can of catalytic cleaner in my tank, it was stuff that cost $25 a can vs. say seafoam that would be $5. I was just to the end of the tank of gas that had this in that I started having the cutting out issues at high rpm. I've been driving it more this weekend with just fuel injector cleaner in it, haven't had a chance to get to the auto parts store yet.
But here's what makes me think it's the injectors. If you're cruising along like 2-3000 rpm running fine & you punch it, the trans downshifts & goes up to like 6000 & it starts running like crap & really not accelerating. I wish I had an A/F gauge to confirm this but if it would show running really lean, that's it. I can't run it long enough like that for it to throw a lean code. But does this make sense to anybody that my thinking would lead me to injectors?
bencor21 is offline
post #5 of 9 (permalink) Old 07-14-2019, 02:18 PM
seymore4's Avatar
Quoted: 49 Post(s)
What you're describing sounds exactly like a failing fuel pump. Unless they checked the fuel pressure under load on a dyno then it doesnt matter. Every time I've seen a fuel pump fail on these trucks it starts by only being noticeable under load and at higher rpms then gets gradually worse. If you can drive normally with no symptoms but it stalls, bucks, etc when you punch it or get into higher rpms, pull a hill etc, I would say it's the fuel pump.
www.cajunbpipes.com
seymore4 is offline
bencor21 (07-14-2019)
post #6 of 9 (permalink) Old 07-14-2019, 03:30 PM Thread Starter
Quoted: 1 Post(s)
Yeah seymore4, highly doubtful they did it on a dyno, maybe on a road test. But what you are describing is exaclty what I got going on. I don't have an issue doing the fuel pump, I at least have access to a hoist where I can just yank the bed & not drop the tank, I've actually done it before on an older truck, I just don't want to keep guessing at this. Truck only has 125k on it & it's still in pretty decent shape. Just right now it's really pissing me off.
bencor21 is offline
post #7 of 9 (permalink) Old 07-14-2019, 05:01 PM Thread Starter
Quoted: 1 Post(s)
Fuel pumps only like $70 on ebay but dropping the tank or lifting the bed both look like a pain. Anybody have a recommendation?
bencor21 is offline
post #8 of 9 (permalink) Old 07-14-2019, 06:45 PM
HRTKD's Avatar
Quoted: 1221 Post(s)
Garage
iTrader Score: 2 reviews
Installing a new fuel pump involves dropping the fuel tank. You do NOT want to do it twice. Buy an OEM fuel pump, not aftermarket. I've had problems with aftermarket fuel pumps. It's just not worth the hassle.
I agree with Seymore4 that it's likely the fuel pump.
«Granite '07 LE Crew Cab, 4x4, Big Tow, Off-Road» <-- Sold 07/2017
«ClearBra, Leer 100XQ, MM SI9500 Winch, Custom b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms, Hellwig rear sway bar»
2015 Nissan Leaf
2017 Ford F-350 CCLB 6.7L Lariat - The Towing Beast
Jim aka Bionic Whore™, Tutu Whore™
HRTKD is offline
The Following User Says Thank You to HRTKD For This Useful Post:
seymore4 (07-15-2019)
post #9 of 9 (permalink) Old 07-15-2019, 04:40 AM Thread Starter
Quoted: 1 Post(s)
Well that's 2. Alright I guess the fuel pump is the route I'll go. Leaving on vacation this weekend so it'll be a couple weeks until I get to it. I'll report back when it's done with the results. Thanks guys.
bencor21 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Linear Mode Linear Mode
Engine sputtering, sluggish, hard to start, dying, shutting down, low rpm, dies etc. bolt37 Titan Engine, Transmission & Drivetrain 5 10-09-2017 07:43 PM
runs fine in reverse zackmullin Titan Engine, Transmission & Drivetrain 12 08-15-2014 06:37 PM
HORRIBLE high pitched knock coming from Engine/Tranny MJR.Bonr729 Titan Engine, Transmission & Drivetrain 0 02-19-2014 11:01 PM
2003 titan runs fine, then just idles down and dies etsufan77 Titan Problems & Dealer Service 5 06-12-2011 08:59 PM
high pitched squeel at low rpm tom0445 Titan Problems & Dealer Service 0 04-17-2006 09:17 AM
You may post new threads
You may post replies
