Problems with rr brake/stop on tt - Nissan Titan Forum
User Tag List
post #1 of 4 (permalink) Old 05-21-2019, 10:27 AM Thread Starter
Quoted: 4 Post(s)
iTrader Score: 0 reviews
So, I have a 2004 that has the basic tow. As in button and 7pin. When I got my tt(travel trailer), last year, I found out I was missing a relay. What automaker doesn't put in a relay, honestly. So, for last summer I used my Xterra. This year, got myself a reese wdh, installed 1 relay. Well my brake controller seems to work, as does everything but the right rear brake/signal.
Now, when I did the relay, I have 2 tow relays, the package came with 3, and most sources seem to indicate there should be 3 relays, but I have 2. And that is all the relay box cover shows. Both are new relays. Ok, so good there I would assume. I went and found a diagram of my outlet, so I can try and test the connections.
And I just read about the 2 little fuses under the dash, which I had actually stumbled across last night. I never checked them, as I didn't know what they were for.
So, when I get home, I'm checking those fuses and the outlet on the truck. What else that may or may not be hidden, should I check for? All lights worked on the trailer last week when I brought it back home from indoor storage.
I ask this as I could probably stumble around all day here, and possibly still not cover everything.
vinmansbrew is offline
Advertisement
post #2 of 4 (permalink) Old 05-21-2019, 11:15 AM
LaxDfns15's Avatar
Quoted: 180 Post(s)
iTrader Score: 4 reviews
Re: Problems with rr brake/stop on tt
Absolute easiest thing to do is check the bulb, and check the power running to the bulb. If both are good then check wiring running to the light. If that's good THEN you move on to the adapter and/or outlet for the lights at the back of the truck. Start from the end and move to the source with anything electrical.
Doesn't matter if the lights worked a week ago. Drove my car to the store one time, got back in it 20 minutes later to drive home and both headlights were blown. It happens.
2008 PRO-4X KC
No chrome, custom 3" lift, Black Rhino Sidewinder 18x9's, 295/70/R18 Pathfinder AT's, Pioneer HU+Two Kicker Comp 12's, LED lights inside and out, Defiant light bar, 32" curved LED bar, amber 20" LED bar, AirAid MXP, Cajun exhaust
LaxDfns15 is offline
post #3 of 4 (permalink) Old 05-21-2019, 11:45 AM Thread Starter
Quoted: 4 Post(s)
I did check the bulb yesterday. One of the first things I looked at. Trailer wiring is simple enough to check, that's why I am wondering about the things that I'd need to check with the truck. Between missing relays, bcm module replacements, ect; I figure I should know the common places to check. This truck has had a farm working life, lots of gravel roads.
post #4 of 4 (permalink) Old 05-21-2019, 07:17 PM Thread Starter
Quoted: 4 Post(s)
So, checked the fuses under the dash and yep, 1 was toast. Lights good. Glad I stumbled across that here. Never would have known about it otherwise.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Linear Mode Linear Mode
ppl can't stop at stop sign The_DarkSide Titan General Discussion 9 05-08-2014 08:10 PM
W/RR or W/OUT RR??? claytonr24 Titan FAQ & How to Area 3 07-30-2012 04:18 PM
Stop Truck Stop!! jasonmotox Off-Topic Discussion 16 04-17-2007 07:14 PM
Clunk Noise in rear end when moving rr tire Side to Side. TEO314 Titan General Discussion 2 12-08-2005 10:22 PM
G-Tech Pro RR Hatchman Off-Topic Discussion 3 06-16-2005 11:09 AM
You may post new threads
You may post replies
