What psi are you running on your m/t tires for highway driving? - Page 2 - Nissan Titan Forum
Forum sponsored by: Discount Tire
User Tag List
post #16 of 20 (permalink) Old 01-06-2017, 06:29 AM
MTKross's Avatar
Quoted: 2 Post(s)
iTrader Score: 0 reviews
Re: What psi are you running on your m/t tires for highway driving?
Originally Posted by 54warrior View Post
Damn, you guys making me second guess myself. I never run more than 35psi. I got 40,000 miles out of my last set of Terra Grapplers.
I was about to right the same as you haha
I've always kept them at the door specs.
MTKross is offline
Advertisement
post #17 of 20 (permalink) Old 01-13-2018, 08:04 AM
12 titan's Avatar
Quoted: 1 Post(s)
Garage
you guys are starting to worry me too...lol. Actually have some cooper pro stts and i go by the tire sidewall - it says 80psi. i run 70-78 psi. my tpms light is on. i've replaced two sensors (one was leaking off air and the other dead). Still have the solid light for no sensor info to the monitoring unit'faulty tpms....guess i should figure out the reset proceedure and see if it will work correctly since i have a commiewealth state inspection coming up. i'm sure they will hit me on that. hmmmm maybe the bulb will fall out? lol any insight on reset ( i think there is a thread on here if i can find it) or if my high pressures would cause this? (i doubt since it is just a low pressure sensor) thanks titan talkers.
12 titan
2011 Titan 4x4 cc, sv, black
eastern va
American racing ansen offroad 18x9 (0 o/s)
Cooper Discoverer Pro Stt 285/65
Bilstiens up front, Pro Comps rear, w/ DK UCAs
12 titan is offline
post #18 of 20 (permalink) Old 01-13-2018, 11:12 AM
dubyam's Avatar
Quoted: 184 Post(s)
I run 46 cold in the front, and 42 cold in the back, on my 2011 Pro4X CC. Tires are 1st Gen BFG TA/KOs in OEM size, but E load range. I'm getting very even wear, and with 38k on the tires, I still have a quarter to a third of the tread left. These will break 50k easily, and may make 60k.
Set up your tires so the contact patch is right and you will get best wear, handling, and braking. Running at max psi on the sidewall will wear out the centers way early unless you're always carrying max load.
dubyam is offline
post #19 of 20 (permalink) Old 01-13-2018, 08:31 PM
Quoted: 52 Post(s)
Door specs only apply to exact size/load rating of tire listed
wanderMT is offline
post #20 of 20 (permalink) Old 01-13-2018, 09:52 PM
mallthus's Avatar
Quoted: 13 Post(s)
I ran 5psi off max for while on my 2015 Titan and it always lit the TPS light. Spoke to the service manager at my dealer and he said the TPS light will always come on at anything over 50psi.
Sent from my iPad using Tapatalk
mallthus is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Linear Mode Linear Mode
Weird problem while driving on highway! Dakota Titan Titan General Discussion 9 02-07-2010 11:36 PM
What PSI R U running on LT tires? WildMike43 Titan Wheels, Tires & Brakes 6 08-13-2009 09:12 PM
Diff Lock On By Accident While Driving Down Highway al120hp Titan General Discussion 7 12-26-2005 06:33 PM
Highway driving max805 Titan General Discussion 8 11-02-2005 03:58 PM
You may post new threads
You may post replies
