More parking brake woes - Nissan Titan Forum
Forum sponsored by: Discount Tire
User Tag List
post #1 of 4 (permalink) Old 05-13-2019, 11:43 AM Thread Starter
Quoted: 0 Post(s)
iTrader Score: 0 reviews
Hello
I am having an issue with squealing from the rear while the vehicle is in motion, any time it is in motion at any speed, regardless of steering, throttle input.
I have a feeling the noise is coming from the parking brake, here is why:
The noise goes away when the parking brake is applied while driving. This to me suggests that the problem is parking brake shoes that are dragging enough to make noise, and that when the park brake is activated it applies more pressure to the inside of the rotor - enough to start doing actual braking, and the noise stops. Upon releasing the park brake the noise starts again.
Is this a logical diagnosis?
I am thinking if it was brake drag from the disk brake system I would hear it regardless of the state of the parking brake. Worth noting is that my parking brake will currently NOT hold the truck back even on flat ground and with no throttle applied.
Here's what I have tried:
Replaced park brake shoes, both sides
Tightened and loosened the adjusting nut at the pedal (This nut feels like it makes no difference and that I need to do hundreds of turns. This is of course limited by the fact that tight clearance means I can only do a quarter rotation at a time with my socket driver. Is that everyone's experience with this adjustment?)
Burnished the park brake as per service manual
The most recent thing I did was replace hardware - springs, retainer clips, star adjuster (Note: did not replace lever, did not replace cables).
The springs did look old and quite stretched compared to the new ones so I thought that might have been the problem - weak springs leading to a failure to adequately return to a neutral state after pedal released leading to brake drag. When putting the rotors back on after changing this hardware, they slipped over the park brake assembly without any apparent rubbing. Still the squealing persists.
I believe my pedal adjustment is very backed off at the moment, could it being too loose cause this?
Any ideas on what I should try next? Thank you for any advice you have.
Corey Lunty is offline
Advertisement
post #2 of 4 (permalink) Old 05-13-2019, 05:20 PM
Quoted: 27 Post(s)
iTrader Score: 1 reviews
Re: More parking brake woes
Okay!
Adjust your shoes till you can just get your rotors on! Then start adjusting your nut on emergency pedal in truck! I replace everything on my 2005, due to previous owner screwing it all up! My emergency brakes work like a champ!
Good luck!
cajun56 is offline
post #3 of 4 (permalink) Old Today, 06:25 AM
k9hohriver's Avatar
Quoted: 10 Post(s)
Where can I find a video to watch, my 2005 Titan needs e brake replacement. How hard is it to do, what would they charge at a shop?
Thanks!
Jim
k9hohriver is offline
post #4 of 4 (permalink) Old Today, 11:29 AM
Protholl's Avatar
Quoted: 23 Post(s)
Garage
Thanks!
Jim
2005 Titan LE CC *WAS* "Red Alert!" but now... she's wearing "Galaxy Black"
Protholl is online now
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ak2030
E-Brake Parking Brake Failure 2008.5 Video Nick741 Titan Problems & Dealer Service 53 10-19-2016 06:18 PM
E-Brake (Parking Brake) problem python_one Titan Wheels, Tires & Brakes 10 11-26-2015 05:10 AM
Parking on an incline without parking brake... Elite130 Titan Engine, Transmission & Drivetrain 9 09-16-2013 03:56 PM
2004 XE 4WD crew cab - Trailer brake wiring woes gearheadloco Titan Towing & Hauling 4 10-08-2007 06:59 PM
Could the e-brake be the cause of front rotor woes? Lounatk Titan General Discussion 7 12-23-2004 03:01 PM
You may post new threads
You may post replies
