Hello everyone this is my first time on the forum. I just bought a BDGT and will be installing it tomorrow. Is there any clear instructions on how to install it? Also, how do u remove the WOT? Any help is greatly appreciated.
yeah thats a big one if it lets you get in to tuning and your batterie dies it could mess up your computer my batterie was not fully alive so i hooked up a charger to be sure you should love this tuner i love my bdpp you will hit red lines easy now i know i didAND make sure you have a FULLY charged battery.
RAM Mount Install
It's pretty basic even without the mount for installation. Uploading or changing the programs is pretty basic.
If you need the Ram Mount and HDMI Cable
Yes it was 12.24 93 tune and 12.10 stock tune at the dyno with the sniffer in the tailpipe. I know uprev would be better but I already had the bdgt and could not justify uprev when my afr's were so close to target and with power made and mpg obtained by the ole Cajun titan.You'd think with the technology we have these days, we could figure out how to get a 4WD get the same mileage as a 2WD....
Dang, Nightowl, I figured you'd be running an UpRev tune with LTs. Guess the BDGT is working for you then. FFV helps I guess. Have you checked WOT AFRs yet with the 93 tune?
What grade of gas are you using?Guys I changed to 93 tune the other day and the wife and I went to Natchitoches, La to see the Christmas lights and I achieved 21.17 mpg (hand calculated) running about 125 miles down I-49 at 65mph. I had just filled up and reset the bdgt mpg average before getting on interstate and the average was 19 mpg on the tuner. I have always calculated about 1 mpg more than the bdgt reading when putting the numbers to it. My mods are in my signature and this is the best mpg I have ever recorded. This was 10% ethanol also. I have noticed that the 93 tune on my T is a lot better on mpg than the 87 tune.
Mike, do you run Premium gas with this setting?Premium Setting
WOT Removed
Throttle Sensitivity: Performance or HIGH
+2 Timing Advanced
Speed Limiter: STOCK
REV Limiter: STOCK
93 octane with 10% ethanol, I have got better average mpg with non ethanol gas but this is the best I have ever seen.What grade of gas are you using?
Ok thanks. I thought you would probably get detonation otherwise.93 octane with 10% ethanol, I have got better average mpg with non ethanol gas but this is the best I have ever seen.
To think I got doubted on 20.9 mpg running similar speeds from San Antonio to Fort Worth.Guys I changed to 93 tune the other day and the wife and I went to Natchitoches, La to see the Christmas lights and I achieved 21.17 mpg (hand calculated) running about 125 miles down I-49 at 65mph. I had just filled up and reset the bdgt mpg average before getting on interstate and the average was 19 mpg on the tuner. I have always calculated about 1 mpg more than the bdgt reading when putting the numbers to it. My mods are in my signature and this is the best mpg I have ever recorded. This was 10% ethanol also. I have noticed that the 93 tune on my T is a lot better on mpg than the 87 tune.
