DIY grill install took about 3 hours to complete. Used the metal mesh from Home Depot and painted it with etching primer and Rustoleum black bedliner. I also installed my chrome inserts in my wheels. What do you think??
Thanks! Your posts in the DIY Grill Mod threads helped alot.:read:Great work on the DIY.
There are two DIYs in that thread. One is for the badgeless grille and the other is for the mesh grille mod.I like it, looks good! I read the DIY thread but am confused. Did you put the OEM grill back in behind the new mesh? I am definitely going to do this!
Yes, you use the original inside frame. You just have to cut out the grill part with a hand saw or sawzall. Took a little time but it wasn't too bad. The hardest part is cutting the mesh to fit.I like it, looks good! I read the DIY thread but am confused. Did you put the OEM grill back in behind the new mesh? I am definitely going to do this!
