travisreed said:
Any thoughts as to this working with the 1" PRG rear lift? I know, I want the cake and....eating it too.
It should work, although the roll bar will be tilted up because the length of the push/pull rods will effectively be shortened.
I'm guessing the roll stiffness would change, and it wouldn't be quite as stiff.
I'm quite impressed with the general automotive knowledge on this board
I have yet to see any "what does this do posts".
Also, several people have CORRECTLY pointed out that increasing the rear roll stiffness of a vehicle will cause more load transfer in the rear.
Because tires are NOT linear in their lateral grip in relation to load, the increased load transfer in the rear will result in less grip in the rear vs. the front, resulting in an OVERSTEER / less UNDERSTEER situation.
You may think "well, less grip means less cornering power, what gives???". Because there will be less roll, there will be less camber change in the front, resulting in a larger contact patch for the front and more grip. If the truck seems too loose, get a front ARB, or bigger rear tires.
As a note, this mod (assuming the bushing mounts aren't over-tightened) should NOT effect rear ride height, or performace in two wheel bump. Only roll stiffness (on and OFF road) and one wheel bump will be effected.
I would get this mod, but it is somewhat contradictary to have more / bigger ARB's on an OFFROAD truck (which I have). Less roll = less wheel articulation = less offroad performance.
Just my $0.02 - hope this helps any questions yall might have.
- Mike
