1 - 9 of 9 Posts
KeaneBeane823
hello I installed a black knight 50" led bar above my windshield with rough country led mounts. The bar has led backlighting to change many colors as well as the normal cord. The titan has no room for running it down the door seal or windshield so the only thing I can think of is an additional hole through the roof to run these wires. Any suggestions?!?!? Also the brackets were a pain in the *** to install for some reason so they didn't charge me.
With a proper grommet and silicone, running it through the roof and down the A-pillar would probably be ideal and the easiest route.
I have the 50" led bar and yea you need to drill another hole for the wire of the light it's the only way if you want it to look clean. ?
Not sure how thick the wire is on your setup. My wire wasn't too thick. Maybe about the size of a power saw cord. I was able to get into the track next to windshield under the trim. It required some "finess-ing" and also a plastic vinyl squeegee to help. It looks clean by my standards. You can't see the wire at all as it runs all the way down under the cowl into the engine bay. If your wire is larger than this, than I typed this entire paragraph for no reason.
thanks for your help guys. Love titantalk. I ended up drilling a 1/2" hole in the roof passenger side behind the bracket at the rear bolt. Looks clean. Used a bunch of silicone and ran the wires down the a pillar. Going on road trip tomorrow 500 miles and I couldn't stand the noise from my door not being able to close fully. The wire is pretty thick then I have anothe wire red, green, blue and black running as well for the backlight led. Only cons are drilling and the wind noise I guess from the bar splitting the wind.
That's what I did on mine also. Yes the wind noise is from the light bar.
1 - 9 of 9 Posts
