Vdc, slip, and brake light on
4 reading
25K views 7 replies 6 participants last post by  MartyJones
I have a 2005 Titan that just started getting the vdc, slip, and brake lights on. The previous owner had the master brake cylinder replaced about 6 months ago. Any ideas on what could be causing the problem? I have read that it could be the ABS sensors. The lights come on randomly and turn off after I cut the truck off.
Any suggestions on what to check?
#2 ·
Brake fluid level first.
Reactions: Lee-the-Impaler
#5 ·
There are a several issues that could cause this. Assuming that you have checked the above issues here are a couple more. If it intermittent check the connections at the ABS sensors where they join up to the wiring harness or check the wires from the harness to the sensors. Is your exhaust pipe intact? A lot of times these will rust and come unconnected right after the muffler and the heat can melt the wiring harness there causing massive issues. If all of those lights are on it should be in the rear of the truck so check the things I listed. That's all I've got as far as suggestions. Other than the obvious bad sensor.
#6 ·
it sounds like an abs sensor. I had that same issue.. replace it and back to new..
