I just got an 04 titan KC and everytime the bass hitts even with a stock radio, something makes a weird rattling/vibrating noise. I think it might be the window but cant figure it out. Can anyone have any suggestions?
It's very possible the noise you hear is the seatbelt height adjuster. The adjuster slides up and down and is mounted on each upper sidewall. I never had that rattle, just posting what other members experienced in the past. They thought it was a loose speaker mounting or bad speaker, but it turned out to be that sliding seatbelt adjuster.Silvertitan7 said:I just got an 04 titan KC and everytime the bass hitts even with a stock radio, something makes a weird rattling/vibrating noise. I think it might be the window but cant figure it out. Can anyone have any suggestions?
I would need your truck for a day to find them...lol.Silvertitan7 said:come on guys i need help, its driving me crazy!!
The only things I can come up with since I have the same problem is its in the actual seatbelt device down in the lower door? I have had the panels off both doors on my Titan and found a couple of loose screws on the brackets that hold the panel to the door but that didnt stop my rattle either.Silvertitan7 said:i think i might try to come to that, but in the mean time, any more suggestions?
man doesnt it just drive you nuts!!stevestitan said:The only things I can come up with since I have the same problem is its in the actual seatbelt device down in the lower door? I have had the panels off both doors on my Titan and found a couple of loose screws on the brackets that hold the panel to the door but that didnt stop my rattle either.
Mine is coming at low speeds/rpm's.
I've pushed and pulled on everything in the truck including the seatbelt thing in the lower door. I've even tied down the loose cables that open the latches at the top and bottom of the doors with no luck.
I've searched every titan site I know of and read hours of threads on this and still havent found it. YET!
It does and on one hand I expect more from a truck that costs as much as a titan but on the other hand with all that I've done to it and with it, I should expect some rattles and such. My last truck (Tacoma) had much more rattles and stuff but it was heavily modified as well.Silvertitan7 said:man doesnt it just drive you nuts!!
Maybe if you read what I posted 4 posts ago( I've searched every titan site I know of and read hours of threads on this and still havent found it. YET!)you wouldnt be so quick to try and make a point that all who have been on this thread have already acknowledged or said!Cmando4Life said:people, there are already threads posted on TT about this subject. before you ask any qustions do some research on it...
Silver - I could have swore mine was in the door also. In fact I had my son and my wife on the floor listening and trying to locate the rattle. Metal on metal noise can transmit and give you a false sense of its true location. You might want to try looking under your Titan at the front of the gas tank and see if that plate is your culprit.Silvertitan7 said:cmando im sorry but i did the research and couldnt find what i was looking for. i have a vibration comming from the door all i could find was about underneath the truck and in the back. i guess i just missed the one about the door. if you know were to find it maby you could give me the link?
Steve i checked my underside but its not were its located its deff. in my door. but thanks for the help
