1 - 2 of 2 Posts
Hello everyone. I just got off the phone with superchips and talked to Rich. Last night I had some time, well sort of had some time to do some data logging runs.
I couldnt find the menu selection for lambda data or wideband 02 readings etc. From what I understand it is below the 02 oxygen sensor selection in the menu. When I first got my programmer I thought I saw that selection and started looking at it and wondering with the heck is lambda? Now I cant find any menu selection that shows that info. So my run just had 02 voltages and MAF ratio and rpm. My altitude is about 2200 ft. with an 05 titan AEM brute force and it was 65 degrees if you would like to compare your maf numbers to mine. If you have an 04-06 titan and an cortex please tell me if you have the Lambda info or B1 S1 WR, B2 S1 WR readings? Superchips said they would get back with me later.
Discussion Starter #2
FYI, this is what I received from [email protected]:
"Trim is what you are looking for. Run all 4 O2's in that mode and match the leanest to the Lambda data list provided online."
THANKS AGAIN SCOTT YOU'RE THE BEST!
1 - 2 of 2 Posts
