1 - 1 of 1 Posts
04-06 Nissan Titan 6" ProComp STAGE 2 Lift KIT 2WD 2X4 With 35/12.50R18LT Tires
BFGoodrich Mud-Terrain T/A Tire PROCOMP K6002BMX Complete Kit----------2WD Titan
• Welded one-piece box section cross members are constructed with 3/16” thick steel. Laser cut materials and computer analysis insure accurate fit and superior strength.
• Extended nodular iron steering knuckles are CNC machined for precise fit and alignment
.• MX2.75C coil over shocks with MX6 adjustable rear shocks.
• Cross member compression struts and extended sway bar links included.
• Billet aluminum rear 6” lift blocks
• Factory rims can be used with 35” tires
• Titan kits include rear driveshaft carrier bearing adjustment kit to reduce launch vibration
35/12.50R18LT BFGoodrich Mud-Terrain T/A Tire
3-Ply Polyester Carcass TriGard Construction
-Allows The Tire To Mold Itself Around Rocks
-Computer Designed High Void Lug Tread Design
-Dual Compound Tread -Long Tread Life And Enhanced Traction
-Stiffer Tread That Improves Steering And Cornering
-Two Full Width Steel Belts
I have purchased this Kit less than 6 months ago. The tires have a lot of tread left and everything is in excellent shape.
$3000 plus Shipping
Edwin
Contact: (214) 243-9330
1 - 1 of 1 Posts
