I can guarantee everyone on here will recommend the Cajun fix (headers + b-pipes + UpRev), and for good reason. Replacement manifolds still aren't cheap, and you're eventually going to run into the same problem again (you don't want to do the swap twice). I have the same truck as you (05 Off Road) but didn't make it nearly as long. I did the Cajun fix last summer and was all-in for around $2k (I did JBA long tubes, Cajun catted b-pipes, JBA catback, and UpRev). The process isn't fun, but it's definitely worth it for a permanent fix and some extra HP :smile:
