Okay guys, gonna need some opinions on this one,
Just got back from an oil change and they said my trans cooler lines were leaking and I was a little low on coolant. I've had to top off my coolant before so this is a little concerning. Trans fluid looks dirty but not a milkshaky.
I know the titans have a history of the internal plastics cracking and feeding coolant into the trans and I was wondering if this is what I'm starting to see.
If so, I have found the Long Tru-Cool LPD Transmission Oil Cooler 4588 19,000 GVW External Trans Cooler, would I need to replace the radiator as well?
I've also found the STILLEN NISSAN TITAN, ARMADA / INFINITI QX56 PREMIUM HIGH-PERFORMANCE ALUMINUM RADIATOR - 401446
Which also shows it can do internal Trans Cooling like the OEM but better build
So do I need to replace a bunch of parts?
If I need to replace, can I do it in sections or could it be best to do at once?
Would it even be a good idea to do the external trans cooler because of the cold Nebraska temps?
What's your guy's opinions on this
