Tough to say without looking at it. But one thing I can tell you is the cracked manifold is a $2k repair, so figure the value of the truck is significantly reduced by that one line item.
Check Kelly Blue Book or maybe have a dealership tell you what they'd give in trade (like Carmax or some such).
Depends on what you want to do with it. Keep? Sell? If you want to know what it's worth if you are thinking of selling, go to kbb.com or Edmunds.com, and use their value calculator, as Dub' said^^^. Either site will allow you to enter the options your truck has, and select a condition, which includes something to the effect of "needs TLC." It also adjusts for your region. Will give you a pretty good idea of value.
What's it worth to you? If you like the truck and want to keep it, simple PM (even with header replacement) will always be cheaper than a new or new/used truck.
Going to sell it got a company truck so no need for it anymore.
I did the KBB thing and it said 4400 and up depending on condition. I am in cali and have been looking at the used trucks in the area and they are all listed at the least $6500 in similar condition.
Guess I will start around $7500 and see what happens.
Thanks
id take the first $5k offer and run.
I think KBB is optimistic to get 4.4k but better off starting high and lowering the price. You can't go up unless it is a house in which case you might end up in a bidding war :)
