tech12volt said:
Also the king cabs have wiring problems in the rear doors as well.
Good point tech. There is a recall for '04-early '06 kingcabs due to the wire covering between the cab and the door. The wires may have shorted and caused a problem in your system. Your dealer can let you know if yours is included. You can check yourself and see if the covering over the rear door wires is split and see if any of the wires have broken.
Here is a copy of the recall wording:
NTB07-009
VOLUNTARY RECALL CAMPAIGN 2004–2006 NISSAN TITAN REAR DOOR HARNESS
Nissan has determined that on some 2004 – 2006 model year Titan King Cab vehicles, a defect that relates to motor vehicle safety exists.
In some affected vehicles, there is the possibility that the wires in the harness routed through the rear doors and into the body on each side of the vehicle may break due to over bending of the harness as the doors are opened and closed. The wires in the harness control various systems including the seat belt pretensioners, the passenger side seat belt tension sensor, and rear audio speakers.
If the wire for the seat belt pretensioners breaks and makes contact with a wire for the speaker, there is a possibility that the pretensioner may deploy and tighten the seat belt. If this happens when the belt is retracted, it will not be possible to use the seat belt. If one of the wires for the seat belt tension sensor breaks inside the passenger side harness, the passenger side front air bag will not deploy as designed in a frontal crash. Nissan is conducting a Voluntary Recall Campaign to inspect the wire harness cover for damage and, if necessary, a new wiring harness with a new type cover will be installed and
rerouted.
