06 Nissan Titan will not turn on!!!
906 Views 5 Replies 2 Participants Last post by  Xvur
So recently my 06 Nissan Titan does not won’t to start so I changed out the starter and battery and when turn the key I hear one click but does not crank or anything. the lights do come on and a/c blows when I leave the key on accessories but I did notice when I hold the key when trying to start it sparks come out the positive terminal and, yes I did clean them off. so I’m going to be changing the battery fuse that’s on the positive terminal if y’all have anymore suggestions or think you know how to fix this problem please let me know
1 - 6 of 6 Posts
It's your transponder key. You need to use it. It's either dead or your using a spare..
Sent from my SM-G998U using Tapatalk
Reactions: 1
You need to use the main key, the one that opens the glove box, etc. If you are using it. Then I bet it's bad.
These trucks have a sensor right one the side of the ignition that has to sense that chip that's one the center of your main key. The fool who owned my Titan last thought it was a good idea to drill through the center. Thank God he missed that chip....
Everything will do exactly what you said.. it will turn on. Lights, radio, everything. But if you try and turn it over, you'll get nothing....
Reactions: 1
I got it turned on now so it wasn’t the key I changed the battery fuse and it started right up on first try while not being turned on for a week but I saw some white smoke it smelt burnt but not sure if it was because of the fluid that spilled while taking off the manifold to change the starter or if I did something wrong but all the hoses are connected and everything looks to be good
1 - 6 of 6 Posts
