Did they change anything up front? It looks like my 08 sits more level then the wifes 07.
I agree that the '08 visually appears to be more level (less rake). But it may be an optical illusion because mine is the LWB and thus longer. Or it could be the extra weight pushes the rear down a bit to make it more level.
So if i got the leveling kit would that make it sit up higher in the front?
PRG recomends the 1.3" spacers for the front only on the 08s
PrerunnerGreg said:
The '08 use a thicker wire for the front spring and sit about 1-1.5" taller.
Yes, what Greg said. I had the same thoughts about the less rake too. So, when I was at the dealership last, I measured with the tape measure the front wheel off of the fender to the center of wheel and it was around 22" or 22-1/4" (compared to the earlier models which is 21" from center of wheel to the fender.
wow i didnt know that
are the spindles taller too?
or the same
by the way
i am starting a new site
it is a forum like this one but i am an off-roader (if money will alow)
come take a look linky
