1 - 3 of 3 Posts
Hey guys,
Planning on getting a spacer lift and want to put 35" inch tires.
I've read about PRG and about how great Greg is, but I've emailed him two times in a month and have yet to get a response from him. And the PRG website is outdated on certain things so I'm guessing he's not around anymore?
So I've been reading around and doing anything more than 2.5" inch lift will give you coil bucket contact?
If I get a 2.5" inch lift and a 1.5" rear block, will that be enough to clear 35" tires? Don't want to pinch weld or mod or cut anything. Will only use for normal street driving, no off roading.
But if I can't do 35's then I should definitely be able to do 34s right?
what wheels will you be running and offsets? when i just did they Maxtrac 4" spindle lift on 20x10 -24mm on 35's i rubbed big time!
1 - 3 of 3 Posts
