In the mornings if it is cold, say in the high 30's to low 40's my truck will not crank. Turns over like normal but refuses to start. Once the sun comes out and it the temp has warmed up , the truck cranks right up 1st time. I had the same problem last year and had the alternator, battery, IPDM and the ECM replaced. All of them seemed to solve the problem temporarily, until finally the ECM seemed to fix it once and for all.
Buddy of mine thinks it is some kind of voltage issue so last night I hooked up a charger & set it to slow charge. This morning it started up just fine.
Any suggestions ? I guess it could be the ECM again but I'm just thinking there has to be some kind of other issue here.
