1 - 2 of 2 Posts
Hello all,
About a month ago I had an issue with my titan when I tried to start it. I drove the truck to work, turned it off and returned to it after 20 minutes. When I turned the key it would not crank. I replaced the battery, which seemed to fix it at that time. Earlier this week, I again had the same problem, turned the key but no crank. After cleaning the battery connections I was able to get it started once again. Now the truck is sitting at my work, unable to start once again. However, this time the truck will crank but will not start. It sounds like it is being starved of fuel. I have no SES light, it has 1/2 tank of gas, when I turn the ignition on I can hear the fuel pump engaged, I have cleaned the battery posts again, checked all fuses and did the ECM relay swap with the fog relay.
I am stumped as to what could be wrong. Unfortunately it is sitting in the parking lot at my job so my access to tools is limited and the closest Nissan Dealer is 50 miles away.
Anyone experience this before? I've seen similar issues on here and I have tried those diag steps.
2017 texas titan 4x4
I was going to say that some others have had similar trouble but I cannot recall what the fix was. Sorry
1 - 2 of 2 Posts
