The recall should include the 04-06's also. My TPMS light comes on every time i drive over 40mi. I run 36-40psi and still get the light.
I always thought you were supposed to air them up to what the sidewall rating states. Mine state Max load xxxxlbs @ 44psi. So I run 44 psi.ecmeyla said:You running 44 psi in your tires? I'm only running 36 psi in my 265-70-18's
Impact wrenches can deform the wheels. They can also pull the rotors out of alignment, causing run-out and brake judder.BobNYC said:Don't mean to hijack the thread but....
In the TSB , it says to hand-tighten the wheel nuts and there is a graphic that says "No Air Tools". Why? I've had the tires rotated twice now on my '07 and both times they used an air impact wrench.
At the least! But thanks for the clarification.cneary812 said:If you brought that tsb in with you and held it up to the mechanic while they changed your tires and said, "hey NISSAN says do this"... I bet you get a nasty look... :cheers:
luvbelly said:It seems like a lot of people have problems with this system. Is it really that important to you guys? I check my tire pressure often just out of habit. Is there a way to disable the system if I start to have these issues as well?
Ya know if more people thunk like this, we wouldn't need no stinkin' warranties! :lol:luvbelly said:CNEARY812....I love the tape idea, I was thinking about just taking a hatchet to the gauge cluster until the light doesn't work anymore. Then I could run any tire and wheel package I want with zero issues.:cheers:
kha4079 said:well i have a regular titan crew cab and my tires went down to 35psi and theyre supposed to be at 44psi. they havent came on at all,.... is that considered for a recall???
