1 - 13 of 13 Posts
One night I was driving my truck around and it started to slip really bad to the point where the truck wouldn't move in any gear or reverse. So I parked the truck and 2 weeks later I got in it to see if it would move and it drove fine for 2 days then it started to do it again. Suggestions anyone?
1. Check the transmission fluid level. The Titan transmission can be rather sensitive to being only a quart or two low.
2. While checking the level verify the color of the fluid. If it is any darker than a light strawberry color then you have may have a costly problem.
You can try replacing the fluid and cleaning the filter. But it doesn't look good for the home team.
Any codes?
How about that huge plug under the passenger side? Ever had any connections apart?
1 - 13 of 13 Posts
