1 - 1 of 1 Posts
Hi all,
My front blower is no longer working. I’ve had a variety of electrical issues for the past couple of years. After the last repair and electrical diagnostic, I had a resistor replaced which resulted in the system working again. The blower would work except in the maximum setting. It would shut off after a second or two. I replaced the filter (which did not look like it had ever been replaced by the prior owner). I’ve checked the fuses and replaced the blower. My only other guess is the resistor may have gone out again (due to strain from a bad blower maybe?) and will also need replaced. I don’t have a tester and I’m not sure how to use one.
The rear controls work and I’ve been using that to keep the temperature somewhat bearable inside. Any other Suggestions on what might be the problem?
1 - 1 of 1 Posts
