1 - 8 of 8 Posts
dc_909 said:
6399 Gawr Fr.
4200 Gawr Rr.
Interesting numbers, far exceeding what the tires or rims are likely rated on the front. Fr and Rr always exceed GVWR. Nice to have some capacity though! ;)
That's OK, We gotta dream sometimes! Gotta be able to hold that Diesel someday! lol. :)
So, it is 3699 GAWR Front and 4200 GAWR Rear. Plenty for me...
I thought the axle got a bit larger (but only from what I read; I have no direct knowledge). It did sound like they fixed a few weak links like the spring shackles. Depending on what was the previous limiting factor, you could get a higher GAWR from just bigger tires, or even higher tire pressure recommendations. Tires that aren't running at the max 44 psi get derated quite a bit, in addition to the 10% margin taken out when P-type tires are used on trucks/suvs.
1 - 8 of 8 Posts
