Is the 08 leveling kit the same as my 05 kit? Both are 2wd. I thought I read that the 08 sat taller in the front but I haven't seen mine yet, hasn't arrived at the dealer.
Rick Guess said:i think they are already leveled right?
here is a shot of a 4x4 long bed
http://www.4x4titan.com/4x4_Titan/index.php/topic,138.0.html
mine is the blue one and it has a 2" kit on it
blizzardtitan said:Measured the front of the 08 from ground to fender at 36" and the back at 37 7/8" so using the 2" kit I should be right at level front to back. My old truck had no problems with any contact, so with using the 2" kit on the 08 will that be equivilant to my old truck. Should I just order a 2" kit for a 4x4 and that would work on my 08 2wd. thanks
i am wondering the same thing. i need camber adjustments tooblizzardtitan said:so you raised yours 2.5" and before that you were level at 37" front and back? Mine isn't that level stock. Greg is it ok to go that high?
Take some pics.Peytons_Titan08 said:i am wondering the same thing. i need camber adjustments too
