1 - 2 of 2 Posts
hello, if i understand correctly i could possibly install 08pro4x or 08 4x4 front coil overs on a 05 2wd and gain a little lift on the front?? how much would i gain? is there a difference be tween the pro4x and the regular 4wd coil overs?? any clearance issues with either set up ?? thanks in advance!!
Super Moderator
They're about an inch taller, but I don't know if there's a difference between the two you mention. I suspect not, but can't say for sure.
1 - 2 of 2 Posts
