Ok, I have done this recently so by memory here goes... Unplug all the plugs located on the drivers side bumper bracket. I think there was 4 plugs, maybe three. One of the wire looms is held to the bumper bracket before the plug, so that needs to be cut to release the wire loom when you remove the bumper. Remove the bumper bolts and set the bumper on the side to start taking it apart. The plastic pads are pretty easy. I used a set of pliers to squeeze the clips as I pulled the plastic pieces away from the bumper. Then remove all the clips holding the wire looms for the plate lights and sensors. The plate lights are easy, just pry from the correct side. It has a hook type thing on one side and a clip on the other side. Push the clip in and pull that side out. The sensors took me the longest to figure out. They do not turn or anything like that. They are TWO pieces. The first thing you have to do is remove the sensor from the mount. There is a clip on each side of the sensor mount. Pry the 2 tabs out and pull the sensor out of the mount. Then you can push the tabs on the sensor mount and remove the mount. If this seems confusing, and you cant figure it out once you get there, let me know I will try to explain better. Sorry I dont have any pics.
