1 - 3 of 3 Posts
My 08 titan wont start. The starter, alternator, fuel pump is good and it has a new battery. It turns over like its going to start but then just cuts off. The shop said they cant find the problem but think its a fuse. Any ideas which fuse or what type of electrical problem it could be having.
Thanks Josh
Fuse list is under the fuse cover. I just had the fuel pump and tow mode fuses blow due to the wiring harness to the rear being burnt, still working on it. Buy yourself a mini blade kit. Also the panel on the dash (passenger side, beside or inside the glove box) should have a little tool for pulling those tiny suckers out. Start checking, and good luck. Whatever system it happens to be, check all your wiring. Fuses usually don't blow for no reason.
Thanks Josh
When it "turns over like its going to start but then just cuts off" does it actually start for a second, then shut off? If so, you may have an alarm or key issue.
1 - 3 of 3 Posts
