Based on what I'm seeing your running pig rich but you may be in luck. I noticed on that last video that your AFR was at 18.6 when you let off the gas. Are you sure you have the AFR conversion set on the correct one? Conversion A is for 07-2011 and Conversion B is for 04-06 Titans. Hope this is your problem so you can go run another and post it up.
PS: If it's set on the correct one it will idle on 14.2-15.0......somewhere in this range.
