Supporting Vendor (Gold)
Hello titantalkers!
Just wanted to let everyone know that we're extending a 10% discount code on KYB struts and shocks.
As you know KYB is a leader in manufacturing the highest quality strut and shock components to give you the smoothest ride possible.
Now until May 25th, type in TITANSHOCK at checkout to receive your discount.
If there's anything I can do for ya just let me know:hi:
u may want to check te date u entered for the discount code. we are in april... and the discount expired in march.. how good would this shocks work offroad...?
Discussion Starter #4
Oops, my bad. Meant to say May, code is good.
These aren't triple bypass King offroad shocks, but you should see moderate offroad performance with these shocks. Here is what KYB has to say about them:
High pressure premium gas filled shock absorber to keep your tires glued to the ground.
Gas-a-Just shocks are designed to deliver control and performance. KYB's higher gas pressure and monotube construction provide heavy duty rugged durability and premium ride control. Velocity sensitive valving self adjusts for maximum comfort under changing road conditions while the patented KYB check valve prevents gas/oil foaming. Micro-smooth hard chromed piston rods aid in prevention of the most common cause of shock failure, seal leakage.
