1 - 3 of 3 Posts
I'm looking to get a bull bar and am leaning toward the Hunter SS. My only issue with it is that it only allows 4.5" lights (although I have seen posts where people say they fit 5" lights).
Anyway, I really wanted to get the KC 130 watt Daylighters but I won't be able to fit them as they are 6" in diameter. I could go HID but I want the aux lights to come on with my high beams so I don't want a delay as I cycle them quite often.
Does anyone know of a 130 watt light that will fit on the Hunter bull bar?
Thanks..
Super Moderator
If you get a light with an H3 type bulb, it's a simple swap and 130w aftermarket H3s are cheap in a variety of colors. Just make sure the wiring will take the increased amperage of the higher watt bulbs.
Thanks.
Do you happen to know any 4.5" - 5" light housings? I saw the Hella 500ff are used here by some but I worry that the plastic housing will melt with the heat of a 130 watt bulb.
1 - 3 of 3 Posts
