If you don't mind wandering up to a 275/70/18 tire, you will find a bunch of LT, aggressive tires. A 275/70/18 is only slightly larger than the stock 265/70/18 so they should fit on a stock truck.
17" rims allows more sidewall, which allows the tire to soak up more impacts compared to an 18" rim with smaller sidewalls. However, the new trucks only come with 18" rims because the brakes are so large.
