1 - 3 of 3 Posts
Good Morning,
Confirming that 18" Pro XD Wheels will fit my 2004 Titan LE which has factory 18" wheels. I was told that I would need to purchase different lug nuts, but the wheels would fit without any issue. Can anyone confirm this? If so,what type of lug nuts would I need to purchase? Thank you so much!
they have a +44 offset. it'll probably rub the frame, the brakes, and spindles. also it will look horrendous.
I actually solved for this a little while ago. Using a 1" BORA spacer for the Gen1 titan with 14mm lugs of the 2nd Gen and used the 2ng gen 14mm lug nuts. BORA will make them up for you at a cost of about $250. I messaged them on FB and they said they could do it pretty easily.
1 - 3 of 3 Posts
