I'm looking to change my 2009 Titan 18" rims to 20" rims will they fit. Truck is stock, Also can my speed gauge be calibrated for the 20" rims and tires?
They will fit just fine as long as your tires arent too big or anything. You will also need to look into getting a wheel with the correct offset and all of that but I'm not the guy to ask about that stuff. And you can have your speedometer calibrated but you have to buy a separate unit in order to do it. If your going to keep your suspension stock its probably not worth getting the speedometer thing because you wont be able to get a large enough tire to make the difference between stock and new large enough to make the calibration really necessary. I use this website all the time, just plug in your stock tire size and your new tire size and at the bottom it will even show you how off your speedometer will be. You'll see that its probably not very much. http://www.miata.net/garage/tirecalc.html
Email me and we'll talk. I know exactly how all of the tire sizing works to not have to change speedo or calibration. Can even go wider tire on 20's and not impact speedo. Pm me with phone number and I'll call you if you want.
:bandit:
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
