1 - 20 of 21 Posts
I am interested in purchasing the 2 1/2" leveling kit for my 05 4x4 CC Offroad. I saw on ebay people were selling them for $50-$75 and now I cant find them for under $100. Does anybody know a good place to purchase the kit from.
Also, Can somebody shoe me before and after pictures of their Titan? I was wondering if the tires that are on my Titan will look too small if the front is level with the back.
Thanks,
Huston
It will look sweet.....the tire will not look to small unless you got itty bitty tires....LOL
If you got the stock ones it will look fine....
www.prgproducts.com is a great shop to get a level kit...or look around on the forum and you might find a used one.
ebay does have them also...I got mine from ebay for 89.00 about 6 months ago.
yeah what he said and plus a leveling kit is probably for looks and fitting those tires. what you should really upgrade to is a 4" or 7" lift.
Super Moderator
Rick Guess said:
well a leveling kit is mostly for looks but it also helps in clearance for the front
by the way
I am starting a new site
it is a forum like this one but I am an off-roader (when I can afford to be)
come take a look linky
Shameless advertising :hellno:
Thanks,
Huston
Where are you located? I have a set of NCD spacers i took off when i lowered it. Perfect working order, Solid billet aluminum, highest quality. $65 is fine. Make sure you have or will get cam alighnment bolts or you will chew through tires in no time. Only chance you DONT have them is if your truck is made early-mid 06
******EDIT:****** Sorry i saw you want 2.5". Although thats what i have noticed you have a 4wd. You will need a 2" spacer. Here ya go, cheapest prices for top quality comparing or exceeding PRG on spacers. (people will bash all companies, remember its a freakin solid chunk of aluminum) http://www.ncdcustoms.com/
are you selling your kit ?
huston said:
...Can somebody shoe me before and after pictures of their Titan? Thanks, Huston
Here you go...
(Before)
(After)
I am running a 2.5 inch front spacer on my 4x4 with no problems. That is to say, I have yet to hit my coil buckets even while off-road. I am also running 315/70/17 tires without rubbing anywhere (no pinch weld mod).
There are many 4x4 running a 2.5 inch front spacer without coil bucket issues. It just depends upon several variables. There are also 4x4's that can not run a 2 inch spacer without serious coil bucket issues. The bottom line is that it just depends upon these variables.
As for rubbing, I am sure that the only reason I am not rubbing is that I still run the stock OEM off-road wheels.
Let us not stereotype here and use our brains! Thanks.:poke:
Rick Guess said:
aldaman
i am wondering
does you truck hit easy?
it look like it would unless you use after market upper control arms
I've had no major issues w/the UCA hitting the coil bucket. There was a time when the Arms hit the bucket slightly when I went over a speed bump quickly...Which can easily be remedied with either notching/grinding the area of the coil bucket that gets hit or installing aftermarket UCA such as the PRG or total chaos..
i did exactly what you wanna do
i have stock 18"
and a 4x4 KC
it was farly easy (time consuming)
and YES go get a 4 wheel alingment
luck for my my brother helped my put them on at the shop where he works
and he also did the alignment free too... whoohoo lucky me:rockon
Just Posting To See How Easy It Is To Capitalize Fist Letter Of Every Word, A La SMOOTHWHITETITAN .... It's Not Easy, Guess I Need Practice...
oh, the difference in ride and handling, Smooth, is negligible .... primarily an improvement in the looks/stance of the truck ...
1 - 20 of 21 Posts
