There are alot of forums on here with info on leveling kits. Leveling kits can range anywhere from $50-$200 just need to do research. The max you want to go on a 4X4 is 1.5" or you will get coil bucket contact. The max on a 08+
2WD is 2" or you will have the same problem, those of you with 04-07 2WD, recommended is 2-2.5" but I believe you can go up to 3" if you shave a little off the lip of the coil bucket.
This is all from research I did when I put my 2" on my 2010 2wd.
I hope this helps someone.
Good luck with the sell man.
