No it will not void your warranty, and bumpstops are a great idea. That is why I bought the prg kit, it came with them.
nsunz11982 said:
I bought the same kit for my 4x4 but it came with bumpstops. If I install the kit with the bumpstops will I have any problems? I'm not planning on taking it off road.
Install the bump stops, there is no reason not to.
35x12.50's
Has anyone ever put 35x12.50's Nitto Mud Grapplers on the stock 18" wheel with just a leveling kit?? Pic and comments would be helpfull. Thanks
The only thing with the bump stops is, you have to drill the hole larger. The aftermarket bump stop thread that Greg sells is just slightly bigger.
I have a 2.5" level kit on my from Top Gunz. We put the truck on a lift and used another jack to cycle the suspension as far up as possilble and let it hange all the way down and I could not make anything hit. I am only running stock 275/70/18's so if you are going bigger then it may be an issue.
I have a 2008 KC Pro-4x and I was told that the bump stops were for the 2wd trucks with softer springs.... I have no idea if that is true.
