I bought the NCD kit for my 2006 4x4 and it came with bumpstops. If I install the kit with the bumpstops will I have any problems? I'm not planning on taking it off road.
Then forget about lifting the front and lower the rear.:upsidedowSSgtLE08 said:i spoke with gary at NCD and he said if you don't plan on off roading, then bumpstops are not neccessary. i know i don't plan on taking my 35,000 truck off road. no offense to you off road guys!
here here. i take my $37,000 truck off road all the time and love it.BECHLYF said:Then forget about lifting the front and lower the rear.:upsidedow
Yeah but SSgtLE08 has no plans to, so then lower it.:upsidedowkronos2 said:here here. i take my $37,000 truck off road all the time and love it.
I agree, also when you install a leveling kit you lower the shock location lifting the truck. I think the thicker bump stop might prevent the suspension from compressing too much bottoming out the stock shock(in it's new lower location) maybe even preventing damage to it.loufish said:I believe the only bumpstop you would have is for suspension compression, and would do nothing to effect if the UCA(Upper Control Arm) hits the coil bucket or not.
Most kits add a urethane bumpstop that is progressive in nature, which smooths the bottoming better then the flat factory stop. Install the new bumpstop...:cheers:
I can tell you why. When you install them it looks like there will be virtuually no suspension movement before the bumps stops hit. I know the wheels move much more than the bumps stops do, but it looks like you will really limit the amount of suspension you have left.loufish said:Can I ask you a question?
Why DON'T you want to run them?
You've been looking for a reason not to, why?
Agreed 100%!!! Also you have a 4X4 and purchased the 2.5" kit, if you are really gonna install this your going to want the 2" kit.....BECHLYF said:Then forget about lifting the front and lower the rear.:upsidedow
OK, I thought it might be that, surprised it didn't come out in your original post...I can tell you why. When you install them it looks like there will be virtuually no suspension movement before the bumps stops hit. I know the wheels move much more than the bumps stops do, but it looks like you will really limit the amount of suspension you have left.
Really need to see what is going on, like maybe a PIC.:upsidedowQuartz said:I can tell you why. When you install them it looks like there will be virtuually no suspension movement before the bumps stops hit. I know the wheels move much more than the bumps stops do, but it looks like you will really limit the amount of suspension you have left.
midnightmadman said:I installed the 2" kit from NCD last spring. I didnt install the bumpstops. This past fall I hit a big cross street "jump" where one street is higher then the cross, and I blew BOTH shocks out. I had to replace both shocks and I installed the bump stops.
Does that help you decision?
Even though the bump stop's are close at ride height I dont think they will have a negative effect to your ride. They will just smooch down:upsidedow and maybe save your shocks.I agree, also when you install a leveling kit you lower the shock location lifting the truck. I think the thicker bump stop might prevent the suspension from compressing too much bottoming out the stock shock(in it's new lower location) maybe even preventing damage to it.
