1 - 8 of 8 Posts
I noticed when installing the shock assembly with my 2.5" spacer that I had to drop my lower control arm a good ways to line up the lower shock mount with the mount on the control arm. When I get my 5100s when fully assembled with the spacer is the overall length of the assembly going to be longer than stock? I know the 5100s provide lift so I thought they would be longer. If so has anyone had any problems reassembling with this type of set up? Thanks!
You will probably get coil bucket contact since you already have the 2.5" spacer. The 5100's will provide 1/2" of lift on the "zero" setting, and that is 1/2" of spacer lift. So it will be like a 3" spacer, which will most likely cause coil bucket contact. I do know that a 1.5" spacer with the 5100's on the middle setting will get you about 3" of lift with very minimal contact. This is what I am running.
How does a strut provide lift? Is it the strut or the mounting bracket it uses? If a strut is stiff enough to cause 1/5" of lift I dont think I would want to run it...
The 5100's are a 1/2" longer than the stock ones, so it will provide a little bit of lift just buy being longer. However, there are 3 setting on the strut that you can change to preload the coil (from 0" to 2") to provide lift. Yes, by preloading the coil you will get a stiffer ride, which is why the top position isn't recommended.
THE 1.5" spacer would be best .......the pre load u r using on the 5100's wont change the height of the strut....just how much lift and the stiffness of ride u get by compressing the spring upward for more height.....thats why using a 4x4 coil which is longer and stiffer give more lift.........
I've already got the 2.5" spacer and I was looking for a little more lift while keeping the uca/coilbucket clearance as much as possible. I wasn't sure if there was any way to pull it off without the use of upper control arms.
Spring preload.
1 - 8 of 8 Posts
